Konica Minolta Magicolor 4690MF Multifunction Laser Printer Logo
A
Anonymous Posted on Dec 02, 2013
Error code c340 - Konica Minolta Magicolor 4690MF Multifunction Laser Printer
Norman Weimar
Level 3:
  • Konica Minolta Master 7,035 Answers
  • Posted on Mar 04, 2018
Norman Weimar
Level 3:
Answers
7035
Questions
Helped
1911507
Points
11959
Check the code because not in the service manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
2helpful
Will a sdhc memory card work in a kodak c340
According to the manual, the C340 uses SD and MMC cards, not SDHC cards.
7helpful
Frozen touch screen on
hold down the power button when you turn it on until the calabaration screen comes up and that might fix your problem
2answers
Error when downloading map updates
Try using a different website where you can download the maps for free. These should work. If they don't, you might need a software update from the same web site before getting more maps: www8.garmin.com/support/collection.jsp?product=010-00401-20
1helpful
2answers
My Garmin C340 is dead!!!!
I had the same problem on a trip. Required two fixes and once I did this the unit worked fine.
1. Replace the fuse in the car adapter (reason it wasn't charging when I used it in the car).
2. See the users manual on page 31 regarding resetting your C340.
http://www8.garmin.com/manuals/StreetPilotc340_OwnersManual.pdf
C340
Make sure you are outside with a clear view of the sky. It will lock faster if you are not moving.
Garmin c340 user's manual
This should be available from Garmin. Check their website at www.garmin.com. Click on the C340. It may be available online.
Cannot transfer photos from c340 camera
Make sure that the camera has sufficient power when connecting and aslo try connecting the cam w/out the sdcard
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
