I have minor shutdown problem with mail, won't close or shut down. My ans top left APPLE drop down, force closure, turn of each programme listed. For me works a treat.
Android is corrupted. You need to factory reset it. Hold volume down and home buttons while turning it on. You can let go of those buttons once the screen changes to the Android loading icon.
This will erase everything from your phone - so good idea to keep things backed up for incase it happens again.
Near as I can figure, this happens when: - phone battery is allowed to die - pull battery from phone when it is still shutting down (hard to tell when it's finish)
take out the battery, then take out the memory. Put one of the two memory modules back in, and turn it on. If everything looks ok, shut down and put the other one back and try again...if everything is ok...then ok. If it doesn't work after the first one, let me know...
and you are sure the volume is all the way up? If the headphone jack thinks there is something in there the ipod touch will only play through the headphones. you can try to blow out any dust in there with a can of air and that might solve your problem.
myn wont even turn on ..it was just like charged half full!
i had it plugged inot the computer ..and it wa turned on so i turned it off ..like usually when i plug it in it makes a noise then it loads and a list of options comes up now nothing ..before when it was connected ..yesterday.. the screen said do not disconnect now nothing is on the screen ..its plugged in right now .. i tried going 2 windows media player to sync some music but it says nothing is connected!!!
good luck
