1998 Honda Accord Logo
Posted on May 10, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
98 honda accord makes a popping noise on front driver side
Makes noise only when hitting the brakes does not sound when riding. The popping noise sound like it near the front driver side tire
Anonymous
Level 2:
  • Expert 209 Answers
  • Posted on May 10, 2009
Anonymous
Expert
Level 2:
Answers
209
Questions
0
Helped
121122
Points
629
Check your disc pad they maybe worn out already. then check the disc plate also.
3answers
94 Honda Accord ex having a thumping noise come from what sounds like my front drivers side, only happens at speeds over 30mph and only on deceleration (sounds like I'm running over the bumps...
I think it is the control arm they can make thumping and other strange noises coming from under there when you hit the brakes and let them off while your driving. What it does will range depending on how bad they are. The car may also pull to one side.
1helpful
2000 Honda Odyssey making squealing noise when I turn
Sounds like the brake pad wear indicator tab on the inner brake pad as the pads sometimes wear out unevenly due to stiky brake calliper slides. You would have to remove the wheel to inspect it.
Rubbing/grinding noise
Usually the strut bearing will make this noise upon turning a corner and hitting a rut or pot hole when turning. A wheel bearing will make a low pitched whinning sound constantly
2helpful
2helpful
2answers
2002 Honda Civic Noises
It's the brakes wear indicator telling you that the brakes need changing.
6helpful
Front end loud noise like an old bed clunk, honda crv 2000
its probably your sway bar end links, I had the same problem, I replaced both sides and the bushings and no more clunk noise
Anti lock brakes
you need to have your brakes checked on the front and also have them check wheel bearing on that side. when a car sits overnight in humid conditions the brake rotors will rust over lightly, that normally is removed off of rotor after first brake application. it shouldnt do it after you keep driving. abs does make noises though when it is working, sliding, so I would pop my hood and check for abs computer. It has brake lines and electrical connection going to it. Im not saying its bad but just look at its location and see if the sound of it functioning/location seems to make it sound like it is left wheel
Top Honda Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Honda Expert? Answer questions, earn points and help others
