Flashes the LEDS 8 times. what do I chaeck?
SOURCE: have jazzy select series need to know flashing Code #9
Consult your owners manual for the flash code guide. I believe that you probably have a PG Drives Joysitck/Controller, in which case a 9 code would indicate problem with the brake system. Check the free-wheel levers by placing them in the neutral position, and then firmly placing them back in drive. Try to restart. If still flashing, you need to remove the seat and the shroud and examine the connections inside the base of the chair. The brakes are at the end of the motor, and there are thin wires coming from them back to the controller box. Inspect these wires for any damage, and follow them back to make sure any connections on the way are tight, and that the connections for all clip connections are tight.
The brake is electrically operated by a solenoid. If the solenoid has gone bad, then this will also cause a fault code. Contact your dealer for servicing this part. Good Luck.
