2008 Ford Ikon 1.6 Logo
B
Beulah VORSTER Posted on Dec 02, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
THE PETROL CUB IS LOCK WHEN CENTRAL LOCKING IS NOT WORKING
THE CENTRAL LOCKING IS WORKING NOW AND THEN AND WHEN IT IS NOT WORKING, THE PETROL CUB CAN'T OPEN. HOW CAN WE OPEN IT WITHOUT CENTRAL LOCKING??
john
Level 2:
New Friend:
  • Expert 95 Answers
  • Posted on Dec 02, 2013
john
Expert
Level 2:
New Friend:
Answers
95
Questions
0
Helped
21025
Points
328
There is a locking pin that runs in conjunction with youre door locks. get the doors to unlock open youre gas door and remove locking pin .this will allow youre gas door to open at all times. hope this helps good luck
5 Related Answers
Anonymous
  • 14 Answers
  • Posted on Feb 05, 2009
SOURCE: central locking on Ford focus 1.4 W reg 2000
hi i would start by checking if there is a relay, it seems that there is a delay on the pressure pump that is supposed to shoot the door pins up.
daveleeyates
  • 65 Answers
  • Posted on Mar 25, 2009
SOURCE: central locking not working on a 2001 Ford Puma
ignition on and off three times, car beeps, press lock button car beeps, remote programmed
gerry bissi
  • 4390 Answers
  • Posted on Jun 23, 2009
SOURCE: 2000 Ford Focus automatic door locks quit working.
check fuse 63 first.
Visual Inspection Chart Mechanical Electrical
  • Binding latch mechanisms
  • Binding linkage
  • Misaligned door
  • Central junction box fuse 63 (20A)
  • Damaged wiring harness
  • Loose or corroded connection(s)
  • Circuit
  • Door lock switch
  • Door lock actuator
It could also be your GEM (generic electronic module) which is expensive as it controls a lot of stuff. A scan tool can be used to cehck for fault codes from the GEM.
andy_lyles
  • 12 Answers
  • Posted on Mar 17, 2010
SOURCE: Focus 2 from 2005 The central locking randomly lock or/and unlock
makesure fuse fore central locking is not loose or just coroded fit new one
roniecon
Ronny Bennett Sr.
  • 6988 Answers
  • Posted on Apr 12, 2010
SOURCE: have replaced battery in keystill the central locking wont work??
reset the fob,,,turn key on,leave it for 10 minutes,then turn it off,and right back on,,do this two more times,a total of thirty minutes,this should reset the fob.
My 06 opel astra 1.6 petrol won't lock on fob. The button on the dash won't work. I have checked all fuses and the sensor for central locking has been changed and this worked only a few days.
seems like you have an intermittent central locking control unit ask some electronic chap to resolder the board for you as they do tend to have dry solder joints or suffer water damage.
My 1997 vw polo classic 18i's doors wont open,it works on central locking with air,i cant manually pull the door knobs up but my boot and petrol cap wont open,ive disconnected the little pipe of the...
The air powered centrol locking is a pain, not the least because of the high cost of a replacement circuit board.
I can't quite remember how I overcame the problem. I think I applied either pressure or suction to the air pipe to unlock everything and then once everything was unlocked I was able to manually lock and unlock each door and in this case the boot lid. The fuel flap was left unlocked without problems.
Ford Focus 2005 central locking problem. how to open trunk and petrol lid manually
I have a key to start my car but no key to unlock my trunk and i have look for a lach it is a 2000 ford focus how can i get in or if i get a key made would it work
CENTRAL LOCKING NOT WORKING HAVING TO USE KEY BUT UNABLE TO OPEN PETROL DOOR TO PUT PETROL IN CAR.
central door locking need further information, but to petrol in is very simple: in the right hand side of your boot straight behind the fuel door you find a cable, if you pull it it will release the door
My central locking stopped working and i cant get my petrol cap housing open to put petrol in to get it fixed! any ideas? any way of unlocking it manually? i have an audi a3 2001
On some cars you can unlock the door twice and this will release the petrol cap - otherwise you could check for a loose conection somewhere in the fuse box.
1helpful
Central locking on megane 2000
is yours the renault keycard to start and open doors?if it is a know these cards can go faulty.they were bad on renault laguna.the switch breaks off the board inside card.can be soldered back on.think you can get replacement switch kit on ebay with instructions how to fix.need someone who can solder with some eletronics knowhow.if not not sure sorry
Electrical problems
i had the same problem. i had to get another central locking motor. but in ur handbook there is a way to open ur petrol can manually i cant remember how off the top of my head but if you dont have ur handbook i will dig mine out. i asked somebody to pick me one up from the scrap yard and they said they were missing from all polos and golfs so i think it is a common fault.
22helpful
3answers
Peugeot 307 1.6 petrol central locking problem
leave ign off with key out 3mins disconnet battery 5 mins reconnett and press lock/ unlock repeatedly until locks cycle through to re sync try this any probs come back to me
Remote central locking not working on my audi A6 2.4 automatic petrol left hand drive but when doing it manually with key only drivers door opens and all indecaters flash quicker than usual
As far as the central locking issue, it sounds like you need to replace your central locking pump. You can buy them online.
I have a 95 A6 and I am in the process of looking for a new central locking pump.
The part number may be 4A0 862 257 J, that is what it is for me.
There are directions online as to how to change this yourself once you get the part. If you buy from the dealership the part is $500.
Be thankful your child locks weren't engaged. We haven't been able to open our back doors since the pump went out.
Central locking problem
i had a similar problem on the front doors .after taking it to a garage for a quote £ 180 i read into it and there are micro swithches in the locks so with a gentle tap with the hand the door unlocks . hope this helps it saved me the money
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
