Watches Logo
A
Anonymous Posted on Dec 02, 2013
The pin is snapped in the end of bracelet strap. Took it to be repaired but can't remove snapped pin. I was told only solution was to replace strap but couldn't get strap to fit width of watch. Straps available are not wide enough
5 Related Answers
A
Anonymous
  • Posted on Mar 23, 2008
SOURCE: Timex 1440 Sport watch needs a new strap
Hi I have a 1440 sport watch , somehow I got it into 24 hr mode vs regular time. Can't seem to figure outhow to get it out of this.....HELP :)
Anonymous
  • Posted on Mar 24, 2008
SOURCE: Can't figure out how to change watch strap
Hi, try this - it worked for me. Use a needle to poke the ends of the watch strap axel (at the end and running across the strap). This should then allow you to lit the silver panels at the top and bottom of the watch face off. The axel should then slide out. I did this by pushing one end of it through with a needle so that the other end poked out enough to pull it out with a paid of pliers.
Anonymous
  • Posted on Mar 28, 2008
SOURCE: Tissot T-Touch T33.7.788.51 Bracelet replacement
Sounds like it's broken @ a factory sealed link (non servicable). Local jeweller should be able to order & fit you a new one
escapement
Arturs Kalnins
  • 2338 Answers
  • Posted on Dec 19, 2008
SOURCE: Strap for Fossil Philippe Starck PH1035 Wrist Watch
Type in your browser FOSSIL WATCHES.
You will find numerous sites. Go thru them till you find what you're looking for.
Anonymous
  • 58 Answers
  • Posted on Jun 22, 2009
SOURCE: How do I remove links from stainless steel
The band has pins in it which can be removed by tapping them
4helpful
2answers
How to adjust strap length?
For removing or adding links firstly you will have to remove bracelet pins or screws. In case if there are screw on each side of bracelet - you have to use two screwdrivers simultaneously. In case if there are pins - read the rest:
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out. First you have to find out what sort of pins or even screws are used to keep links together (screw ends and pin end may look similar). Examine both bracelet sides and find the side where pin ends have a groove. Start with a tiny screwdriver and try to unscrew one. If it turns, but doesn't come out, that means you have a pins instead of screws. For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it. Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well. NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer. Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows. After a few punches check if the split end is coming out and when you see that the pin end is coming out long enough - grab it with pliers and pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting. After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet. It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin. Make sure that pin ends are flush with bracelet. If needed- hit few more times. Job done! If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Feb 28, 2011 • Watches
5helpful
Need help in taking links out of citizen watch strap
Rate me, please.
5helpful
How can I remove alink from my Adidas watch strap?
After buying this model watch bracelet links are rusted and torn with one year of purchasing. When i took that watch to the show room where i purchased. They kept it for 40 days saying that they has to...
mcdevito75 here, Many watches built today are not comming out with replacement Bands (straps, Bracelets) from the factory, the cost of makeing and keeping extra bands on hand is too high, they should at least have a few extra links to replace worn ones. Chances are your warantee is over on the watch and in that case, you"ll have to find another band, Bracelet on your own. Best Bet, visit a small watch repair shop in your area for another bracelet, band, Strap.
Jun 29, 2010 • Watches
Seiko kinetic stainless steel bracelet has snapped pin (both snapped ends still visible and flush in last flared bracelet link between watch body and start of bracelet.) How do I remove snapped pin ends...
There are several easy to follow tutorials on u-tube. It's easier for you to look at these than for me to describe how it is done. Just search "adjusting steel watch straps"
1helpful
I am trying to remove a link from the strap to make the strap fit
First you have to find out what sort of pins or even screws are used to keep links together.
Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
Job done!
Don't forget to rate, please.
6helpful
Trying to shorten stainless steel watch strap
You may or may not have arrows inside bracelet.Arrows are pointing the way the pins must come out.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
Job done!
133helpful
2answers
Tighten wristband of the Nixon Watch , remove links
You may have arrows inside bracelet.Arrows are pointing the way the pins must come out.
After shortening the bracelet,make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
Job done!
Lock on the eco-drivel wrist watch snapped
IF they still make the same bracelet for your watch you will be able to buy a replacement. If the watch is a leather strap then it is much easier as I can guarantee they will have a compatible strap. Contact citizen to see if they have any metal bracelets or leather straps for this watch.
1helpful
I would like to adjust my Pulsur watch strap but I cannot push those tiny screws on the strap
To do that you need a hardened steel pin and small hammer. Use that pin as a chisel and drive the bracelet pins out. Split pin end must come out first. When driving pins back in- blunt end goes in first and split end last.
You can make driving pin from hardened needle by blunting the pointed end.
Dec 17, 2008 • Watches
Top Beverly Hills Polo Club Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Beverly Hills Polo Club Watch Expert? Answer questions, earn points and help others
