Intermatic T101 - 24 Hr. Dial Time Switch - NEMA 1 Indoor Steel Case - Gray Logo
A
Anonymous Posted on Dec 02, 2013
Little gray box sprinkler has no pins - Intermatic T101 - 24 Hr. Dial Time Switch - NEMA 1 Indoor Steel Case - Gray
Gene Haynes
Level 3:
  • Intermatic Master 5,391 Answers
  • Posted on Mar 22, 2015
Gene Haynes
Intermatic Master
Level 3:
Answers
5391
Questions
0
Helped
2603945
Points
14124
2answers
The sprinkler system is shut off but there is still little water coming out of the sprinkler head. What is the cause of this problem?
Water will continue to run back down the hills to the lowest Heads and Some water will come out.It will stop once the water in the lines has Drained out.
Oct 02, 2014 • Garden
Rainbird troubleshooting
It could be not enough water pressure, dirt on the shaft or it is worn out assuming the parts are all there. They are not very expensive you might just want to buy a new one.
Intermatic dial doesn't automatically switch sprinklers
1) Trippers can wear down. Transformer can go bad if model has 24Volt output. Relay can go bad.
http://waterheatertimer.org/pdf/How-to-Set-and-Troubleshoot-Intermatic-sprinkler-timer.pdf
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#sprinkler
2) Add a comment Feb 2013 with model number, and include if this is new timer or older timer that worked before and stopped working.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
I have 4 zones can run them manually; but they will not come on the automatic setting. Springs are strong; timer itself keeps accurate time. I did read inside the box about a "Silver Pin"...
If zones are not advancing, then 1) Clock motor is not rotating dial > replace clock motor, 2) on-off trippers are worn down > replace trippers, 3) or the day skipper is set to skip all days and all skipper pins are pushed down, 4) or sprinkler valve is bad.
The sprinkler timer dial rotates each 24 hours. The trippers cause sprinkler head to turn on zone 1 for example. Zone 1 waters until the dial rotates to part of dial with no tripper. Without a tripper on the dial, the timer turns off circuit to sprinkler. At this point, the sprinkler valve mechanically advances to zone 2 and waits for timer to turn off again. The timer does not advance sprinkler to next zone > the sprinkler valve is designed to advance each time circuit turns off. The timer just turns on and off. When next tripper rotates around, the timer turn on the circuit and zone 2 begins to water.
The silver pin inserted at 12midnight position is for advancing the day skipper wheel.
Open following link for parts and resources:
1helpful
There is a silver pin that fits into the periphery of the timer. I think this trips the smaller dial to rotate. If the sprinkler is set to go off at 4am, where should I place this silver pin for it to...
You have Intermatic sprinkler timer.
The silver pin inserts into the yellow dial at 12:00 midnight, and it rotates the skipper wheel.
Skipper wheel is necessary only if you want to skip certain days of the week, otherwise the timer cycle repeats each 24-hour period.
To skip a day, the skipper pin is pushed down for that day. Leave skipper pin up for days you want to water.
Open following links for more information:
2helpful
2answers
The clock does not move forward. If I manually turn it, then it will work and turn on the system where the pins are. I haven't tried anything to fix it because I don't know where to start. Intermactic...
Sprinkler and irrigation timers are 14 day.
Intermatic has a page with manuals:
Open page, click plus next to timers and scroll down to sprinkler and irrigation timers
http://www.intermatic.com/customer%20service/instruction%20manuals.aspx
It's good to have the manual on hand in case the product is discontinued
That being said, it sounds like the clock motor is bad.
Snap timer free from box and tip out to see clock motor located on back of timer.
Get the number off clock motor
Intermatic site shows pages of clock motors: They are priced high, but cheaper than new timer.
https://www.intermaticstore.com/ASPI700W.pgm?task=menucntrl&menuopt=TM
Aplus supply sells assortment of Intermatic clock motors.
http://www.aplussupply.com/intermatic/timermotors.htm
To search these pages quickly for your clock numbers, use browser Find (Click edit at top of bowser, click Find)
2helpful
How do I install a T8845pv sprinkler timer. What do I attach to the two yellow wires
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/t8845pv%20-%20english.ashx
The timer is used to power a low-voltage sprinkler solenoid valve.
A solenoid is an electrical switch that opens and closes a gas line or water line.
The yellow wires go to your sprinkler system solenoid valve.
The solenoid is the valve that turns water on-and-off.
The 120Volt electric cable that runs the timer connects to the Line and Neutral terminals.
Black to Line terminal, white to neutral terminal
The clock repeats each 24 hours.
Lift and rotate dial until current time lines up with silver pointer
The skipper wheel has pins >> press pin down for each day you do not want watering
Rotate skipper wheel counterclockwise until current day lines up with 14 arrow
Put tripper pins on yellow dial
Each pin represents 12 minutes of watering
To water for 48 minutes, put in 4 consecutive pins
Put pins on wheel at the time you want watering to take place.
To water twice a day, put pins at two different times, and do not put any pins between those times.
My sprinkler has stopped traveling it will travela little then it stops and make a clicking sound and stays stationary how can i get it to start moving.
Here is a tip about how to get parts for your traveling lawn sprinkler and also a great article about how traveling lawn sprinklers work.
Traveling Lawn Sprinklers
heatman101
Top Intermatic Electrical Supplies Experts
Jay Finke
Jay Finke
ZJ Limited
ZJ Limited
Sean Wright
Sean Wright
Are you an Intermatic Electrical Supply Expert? Answer questions, earn points and help others
