Switch does not dim
SOURCE: 3 pole dimmer not completely working
there is not way to know how the wires are run by the description.
it is possible to connct true 3-way switch, it will required additonal pair of wires to all 3 switches (meaning 3-14/3 wire).
so call 3-way switches is only two way. I have not seems a real 3-way switches.
go to the following site. they a connection diag. for the switches.
http://www.homeimprovementweb.com/information/how-to/three-way-switch.htm
SOURCE: Lutron Dimmer Not Dimming But On/Off Works
The type of track heads you are using could be creating the problem. Are the lamps Par 20, Par 30 (screw in base) or MR-16 low voltage (push in base)? If the track head has a small (2"x4") box and uses MR-16 lamps then you need to use a dimmer specifically designed for ELECTRONIC LOW VOLTAGE. Incandescent lights (screw in base) and Electronic low voltage need a different signal to dim. Using a standard dimmer for electronic low voltage will work for a while, but then either the dimmer or the fixtures will go bad. If your lamps are incandescent or halogen you may have just had a bad dimmer. (Not common for Lutron products) but the part number you list should be good for 1000watts and should not be the issue.
http://www.lutron.com/CMS400/TechInfoPage.aspx?id=25531
Please see "Dimming Basics" under the helpful information tab for a better explanations of the two different styles of dimming. Hope this helps!
SOURCE: Dimmer doesn't turn off!
There is one more thing that you can try, turn the power off from the breaker and wait about 20 seconds, then turn back on. If that doesn't fix it you are probably right about the dimmer being bum. It is very rare that Lutron devices are defective. You can contact them directly and see if you can get it replaced since you no longer have the receipt. You may have to send it to them before they will send you a replacement but it beats spending another $50
http://lutron.com/CMS400/page.aspx?id=24679
Testimonial: "Very timely and attentive feedback on my issue."
SOURCE: Lutron Maestro dimmer rocker stopped working
Because the switches are relatively inexpensive, there aren't kits to repair them when they fail mechanically. Your best bet is to get an exact replacement from a Home Depot or such, turn off the breaker switch, and rewire it exactly as it was, using wire nuts and tape.
