Precor 9.31 Treadmill Logo
A
Anonymous Posted on Dec 01, 2013
I am getting a knocking noise on the left side on my brand new Precor 9.23 when I am running on it
My precor efx 546 makes noise like a squeaking in left pedal it seems I tried to tighten pedal but I the whole bolt and screw turn together and the other pedal makes no noise
This squeak is normally caused by a bad bearing in the wheel. In order to provide you with the correct wheel, I will need your serial number. The following link will take you to our Precor EFX 546 page.
Repair Parts for Precor EFX 546 Ellipticals SPORTSMITH net
2answers
Knocking noise
check the sprocket sometimes they are put together with screws and it might be extruding out and rubbing.
1helpful
Clunking noise precor 5.35
Hello
check for slop in the left and right hand side arms and foot tubes.
I'd tighten every bolt you can find.
GymWorld.net.au
Knocking noise from front right end on 98' camry. 99,000 miles, and I am the second owner. first owner kept up great maintanence. I have been advised from large national chain that both front end quick...
I think you should make quite certain at the mechanics' that it is the struts and mounts knocking, and not the lower main ball joints. However worn strut top mounts are the most likely cause.
You don't say where you are but in the US $1000 should get you new struts and mounts both sides, albeit not a top name brand, and a necessary wheel alignment also.
You should not just replace only one side as that will degrade the handling and steering of the car.
Ford mondeo knocking noise rear
Get someone else to bounce the car while you lay on your back and look. We have no idea what the problem can be and you could have left a lot of stuff loose under there. Maybe you didn't tighten everything up. Check it with a friend bouncing the car.
Knocking/bumping sound while pedaling Precor 576i elliptical. It is coming primarily from the right side/pedal on the downward strike. What could be causing this?
It could be the input drive bearings going out. I would suggest removing the back side covers of the unit and inspecting the drive assembly when its in use. Watch for deviations in the the circular motion of the crank arms. If it moves side to side or drops in the rotation its time to have the input replaced.
Top Precor Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
