This issue can occur for many reasons. The most common is an error during shutdown (ie holding down the power button to force power off). The easiest way to fix this is to run the windows repair disc you should have made when you bought your computer. If you do not have this you can order from the manufacturer for around $80. The only other option is to get a boxed retail copy of windows and install that. However if you choose the second you will lose all of your information stored on the computer. I advise you to take caution in attempting any repairs on your computer as any data not backed up may be destroyed. I am not responsible for any data loss occurring from the repair options mentioned above.
SOURCE: aspire x3910 system will not start, error code
i am afraid you will need to restore your windows using your windows disc, is this vista by any chance.
The two main methods in which to take care of Status Oxcoooooof Repair Screen error message:
Advanced Fix (manual update):
1) Start your computer or laptop then log on as an admin.
2) Click the Start button then click Programs, Accessories, System Tools, and next click Restore.
3) From the new window, click "Restore my system to an earlier period" then click Next.
4) Select the freshest restore point in the "select a restoration date" listing, and then click on Next.
5) Then click 'Next' on the verification window.
6) Restart the pc when the rescue is completed.
Inexperienced Computer User Resolution (totally automated):
1) Download the (Status Oxcoooooof Repair Screen) fix application.
2) Setup application and simply click on Scan button.
3) Hit the Fix Errors button once the diagnostic scan is successfully completed.
4) Restart your laptop or computer.
Here is a link to another Status Oxcoooooof Repair Screen recovery utility you can use in case the above option does not work anymore.
