SOURCE: Touch screen not responding at all
The touch pad is dead...it's a hardware issue...go to the vendor or workshop...within a year it is replaced for free.Good luck.
SOURCE: HTC TOUCH HD charging problem
Well hope so you didn't damaged the sensors! try this : use the phone until battery is empty and switches off. then put it on the charger for 4 hours. If no joy,try different battery to make sure that device is not damaged and get a new battery.
SOURCE: Left my HTC Wildfire on charge overnight. Now I
Hi
To remove the back cover
With the phone turned off, hold your phone securely with the front facing down.
With your thumb or finger, lift the back cover off from the small opening (above the camera) on the top of your phone.
You may need to perform a factory reset if this doesn't work, however a factory reset is not a step to be taken lightly. It will permanently delete all your
data (including any contacts stored on the phone and customized settings, and will also remove any applications you've downloaded
and installed.
To do the factory reset
Hope all this helps
SOURCE: My HTC Wildfire is showing
It usually happens to me during text messaging. It means your messages is not sent. You can view the list at "Undelivierd Messages" (Go to Messages, then Menu->Undelivred). Make sure you have a load balance and a good signal, and retry sending.
SOURCE: my htc inspire ,the touch turns on but wont respond to touch
try to unplug lcd and touch from board and plug again, maybe this solve the problem, if persist you need to change it buying new one. (to dissambl and ressembly see videos on you tube), i think this will help you to solve the problem, Don't forget rate my answer.
The best way to unlock HTC is to buyunlock codes from a trusted vendor. Searchthe internet for mobile phone unlocking websites. You will come across athousand websites which can do this. Choose which ever you like. Do look forprice comparisons and the unlocking instructions. Recheck the Model number-Network to which your phone is locked to and the IMEI number before placing anorder. If you made any mistakes in these details these people will never giveyou a refund!!One more thing, before placing an order ask them about theconditions for getting a full refund in the case of a code failure! Think andmake a wise decision. I have personally bought the unlock code for my HTC Wildfire S from unlockgenie.com. It is becausethey have good reviews on most of the mobile phone forums. I got my phoneunlocked successfully from that website. Try the link http://unlockgenie.com/
Warning : Do not enter
any wrong unlock codes on your HTC Wildfire mobile phones. If you enter
over a certain amount of wrong unlock codes on your HTC Wildfire mobile
phone, your phone may get hard locked and sometimes become unusable.
1. Switch ON your HTC Wildfire with a Not ACCEPTED SIM Card.
2. If your HTC Wildfire asks for a PIN code, then enter your SIM card PIN and press OK.
3. HTC Wildfire will ask to enter an "unlock code".
4. Enter Unlock Code we send to you.
5. Your HTC Wildfire is now unlocked.
