Rangemaster Classic 90 (Electric) Kitchen Range Logo
Y
Yvonne Posted on Dec 01, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Front burner , yellow, flaring flames and sooty pans
freddyfox
Level 2:
Sergeant:
  • Expert 237 Answers
  • Posted on Dec 25, 2013
freddyfox
Expert
Level 2:
Sergeant:
Answers
237
Questions
0
Helped
105078
Points
707
Sounds like the front burner gas jet holes are either blocked in places or the gas regulation (air/gas) mix to that burner needs adjusting. Try removing the hub where the gas burns from and cleaning each hole with something like a paperclip and then blowing through it to expel any particals.
2answers
1helpful
2answers
Flame on main hob of range master 110 is yellow and smelly also black sooty deposit left on jets
Ream out all the orifices and air venturi holes on the burner, adjust the air-ahutter, the air-shutter is usually nearer the valve/knob than to the burner. Yellow flame is an imbalance of fuel to oxygen and is creating Carbon Monoxide and not burning cleanly... this is the same problem that can make a furnace deadly. Blue flame=neutral flame.
I just had my furnace cleaned it is a gas rheem. The service guy said it was overheated because of a#3 tube he said the furnace heat exchange is black. What can be do regarding this
I presume you're talking about a gas furnace, even tho the title says Rheem gas water heater. Either way, it works the same for both.
Any black coloring on the heat exchanger is *not* from overheating. Black is from a sooty flame caused by a mis-adjusted burner. (In fact, a sooty flame is less hot). There is an adjustable "air intake plate" for air to enter the burner where the gas enters the burner. A proper flame is made by adjusting this air opening so the proper gas/air mixture feeds into the burner. If the air vent is closed too much it produces a sooty flame.
The age of the furnace is the most important aspect, and that helpful to determine a likely condition of the heat exchanger and burners. Other than a badly adjusted flame, the main thing to watch for is a badly rusted out heat exchanger. But black does not mean rust.
Gas burner on membersmark grill is flaring up. What can I do ?
First, check the burner for grease build up or a build up of grease in the grease pan under the burners.
Also look for rust thru or blow out on that specific burner. If it's rusted through, it will have to be replaced. Also, a build up of grease on the flame tamer will mimic a burner flare up.
Hope this helps you troubleshoot and solve the problem. Thanks for choosing FixYa.
Aug 02, 2011 • Grilling
1helpful
Flame does not burn blue -- it is more yellow and sooty
From what you described, the burner needs to be removed and cleaned and the air shutter adjustment needs to be readjusted. After cleaning and replacing the burner, you can light the unit and then start adjusting the air shutter, until the flames are blue with yellow or orange tips.
Hope this helped you.
1helpful
Regarding charmglow 720-0289. can't get a hot enough flame. cleaned all burners and made sure all orficis on the burner were clear even blew out with air hose
Are the burner flames diminishing as you turn on additional burners? In other words, is the flame size correct when one burner is lit, but too small when several burners are lit? Is the flame a nice blue color or yellow? If yellow, adjust each burner's air shutter at the end over each orifice. Have you tried adjusting the pressure on your propane regulator? (If it's red, don't mess with it) If it's a silver regulator and has a center cap, you can remove the cap to adjust the screw inside, by turning it clockwise in 1/4 intervals until the desired flame size has been reached. It's also possible that your burners have corroded closed somewhat. Do you have cast iron or stainless steel burners? Cast iron burners tend to corrode shut over the years due to moisture. Stainless steel burners just tend to rust away and flake, but usually become flare ups or out of control flames. Anyway, that gives you some things to look at. Hope it helps. Douglas
Jun 15, 2010 • Grilling
Burner flares up when going from low to off
if the flare-up is yellow, it is flakes of ash burning off. if you take apart the burner and the pipe leading to the burner and shake the black powder-y stuff out of it, the yellow flare-up will stop.
1helpful
King kooker will not burn a blue flame, only a big yellow sooty
You may need to resize the orifice, sounds to me like it is too big. If you have an adjustable orifice try tightening it down a quarter turn at a time till that flame turn pretty. Leave that shutter wide open till you start getting a blue flame. Make sure you have no cob webs blocking the orifice.Blow out and remove all rust from the burner.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sooty burning in oven after Natural-LP gas conversion
The conversion was not done correctly.
Either wrong parts or incorrect adjustments to air flow.
4helpful
2answers
Why is my stove causing a thick coat of soot to buildup on my pots?
you have to adjust the air intake holes at the valves. this will give you a blue flame.
Top Rangemaster Kitchen Ranges Experts
Paul Carew
ZJ Limited
ZJ Limited
Kolbrun...
Are you a Rangemaster Kitchen Range Expert? Answer questions, earn points and help others
