Epson Stylus Sx435w Logo
s
susan tipper Posted on Dec 01, 2013
Easy photo print
When we put the set up disc in it says that the easy photo print has already been installed but it does not show up anywhere
ROY ROBINSON
Level 1:
New Friend:
Problem Solver:
  • Contributor 10 Answers
  • Posted on Dec 13, 2013
ROY ROBINSON
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
10
Questions
0
Helped
4294
Points
32
Think you need to go My Computer, Local disc C, Programs, and find the program you want, find its shortcut and copy its shortcut onto your Desktop.
2answers
How do I remove ink cartridge. I have the door open but don't know how to get the cartridge out.
This video shows you how to change the cartridges in a Canon MG2920. The video is actually for the MG2450, but they are exactly the same.
Canon MG2450 Change Ink Cartridge
2helpful
2answers
Error message pic can not be printed as the system for printing is not running
10 Tips for Troubleshooting Your Printer
http://www.pcmag.com/article2/0%2c2817%2c2412253%2c00.asp
My Printer Won't Print
If the printer doesn't respond when you try to print a document, make sure it's turned on and that a cable hasn't come loose. For both USB- and network-connected computers, the printer driver must be installed on the computer you're printing from. Occasionally the driver may become corrupted and have to be re-installed.
You can either do this from the disc supplied with the printer or by downloading the driver from the manufacturer's Web site. Printer makers generally have a page for which you can download available software for different models and operating systems. (You may also have to update the driver so that it's compatible with a new operating system, as many consumers buying Windows 8 computers have discovered.
Not sure if your computer already has a driver installed for the printer you want to use? With Windows, it's easy to check. Just open the printer folder from the Start menu or Control Panel. Depending on the version of Windows, it's either called Printers, or Printers and Devices. It will show a list of available printers, with offline printers grayed out. If your desired printer is offline, make sure it's properly connected to your PC or network. The default printer has a green check next to it. You can set another printer as default by right-clicking on it and following the prompts.
Right-clicking on a printer and clicking on Printing Preferences will reveal the driver settings. By tweaking them, you can adjust a number of functions, including but not limited to paper size and type, default paper tray, print quality, and duplex printing (if available). The printer software installation disc almost always includes a convenient interface to access printing functions, but it's faster to work straight from the driver.
Most new printers include a quick-start sheet, and many include a user manual. You should keep the installation disk and user manual in a convenient place. A growing number of printers include a user manual as a PDF file on the installation disk, or make it available from their Web site. It's always a good idea to download it to your PC.
HAVE A NICE DAY.
Cannon Pixma ip5200 Wont print labels for DVDs
In order to print CD/DVD directly, you must use Canon Easy Phot Print & put your disc on the Disc Tray and then insert to the printer. Then enjoy with the amazing printing
1helpful
2answers
Trying to install my epson stylus dx4400 multi printer without disk how do i do it
Hi
Ok I have put a driver for you to download from my website it is the driver you need this driver for
Epson-Driverdx4400+dx4450 and put the Epson Easy Photo Print
DX4400 and DX4450 will do the same drivers for your printer
Download your driver from my website click on the link and it will download for you.
Link=Driver http://www.4all2sell.com/driver/Epson-Priter-Driver-DX4400and 4450.exe
Link=Photo http://www.4all2sell.com/driver/Epson-Easy-Photo-Print-DX4400-And4450.exe
Please come back to gave Thanks and to let us know all is well
All Best: Pineworks
1helpful
Lost set up disc can not set up printer to laptop
Hi
All Best: Pineworks
3helpful
I want to take the date and time off already taken pictures so I can print the pictures without the date and time showing.
For already taken photos, you would need photo editing software to remove the date/time stamp. With such software you could either crop the photo to remove it, or apply more labor intensive technques such as cloning to cover it. One good, free, and easy to use photo editing software is Irfanview (www.irfanview.com). With this software you should be able to crop already taken photos to remove the stamp.
Nov 10, 2009 • Cameras
I HAVE CANNON PIXMA MP150 LOST THE SOFTWARE THAT CAME WITH IT FOR PHOTOS AND PROJECTS I DID IN CRAFTING IT WAS SOMETHING CALLED SCAN GEAR WAS ONE I THINK?? BUT IT CAME ALREADY ON THE INSTALLATION DISC I...
The "Vista Home Premium Service Pack 2" disk that it is prompting you for came with your computer itself, not the printer. It's most likely labelled "Setup" or "restore" disk - just put it in the drive when prompted and you should be all set!
2helpful
4answers
Stylus Photo R320 "printer driver dealing with CD printing...
I had the same problem and was able to get my EPSON Stylus Photo R220 to print a CD using the following procedure. This should work for other Epson Photo printers as well.
1.     Open EPSON Print CD
2.     When CD is ready for printing do the following:
3.     Select Print from the File menu
4.     When “The EPSON printer driver dealing with CD printing is not installed” is displayed – click OK and select Manual Print
5.     Set Paper Size to A4 and click OK
6.     In Layout select Print Settings
7.     In Media Type select CD/DVD
8.     Then press Print
Th
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
