Gateway ONE GZ7108 All-in-One Desktop PC Logo
Barbara Jameson Posted on Dec 01, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Windows media player won't work - Gateway ONE GZ7108 All-in-One Desktop PC
Brian Sullivan
Level 3:
  • Gateway Master 27,725 Answers
  • Posted on Dec 02, 2013
Brian Sullivan
Gateway Master
Level 3:
Answers
27725
Questions
Helped
5669465
Points
79191
Which operating system ? Which version of Media player ?
Though designed with Windows 7 in mind, Windows Media Player 11 (WMP 11) is fully compatible with Windows XP.
The trick is knowing which version of WMP 11 to download.
Different versions of the software exist not only for Windows 7, Vista, and XP, but also for both 32-bit and 64-bit Windows XP.
Additionally, WMP 11 is only compatible with XP if it is using Service Pack 2 or Service Pack 3. Before downloading the appropriate installation file, you will need to verify which version your system requires.
Open the "Start" menu.
Open "My Computer."
Click "Help", then select "About Windows."
This will display a window with system information.
Find the listing that specifies your Service Pack. If you are operating without Service Pack 2 or 3, you will need to install one (see Resources).
Open the "Start" menu and click "Run." Within the text field, type "winmsd.exe."
Click "OK." Select "System Summary."
Find the heading labeled "Item."
Under this heading should be the word "Processor."
The value associated with "Processor" will determine which version of Windows XP you are running.
If the value begins with "x86," you are running a 32-bit version.
If it begins with "ia64" or "AMD64," then you are running a 64-bit version.
Download the Windows Media Player installation file that matches your version of Windows (see Below).
http://windows.microsoft.com/en-US/windows/downloads/windows-media-player
Open the file once it has finished downloading.
This will launch the installation wizard.
Follow the onscreen instructions to install WMP 11.
The program should now run normally.
How to Fix Windows Media Center
Windows Media Center is the home entertainment hub on a Windows computer.
With Media Center, you can play live television, songs, DVDs and slideshows.
It is preinstalled on Windows XP Media Center Edition, Windows Vista Home Premium/Ultimate Edition and Windows 7 Home Premium, Professional, Enterprise and Ultimate editions.
From time to time, users run into issues trying to play audio or video files, or with an extender connected to Media Center.
Extenders are devices that allow you to "extend" the Media Center onto a TV screen or larger display.
The Xbox 360 gaming console is an example of an extender.
Launch Windows Media Center from your computer's Start menu.
Scroll down to "Music" on the Media Center home screen.
Select "Music library."
If you find an empty folder under "Music Library," navigate to the folder on your hard drive that stores your music file and add it to Media Center's library.
If the problem isn't an empty folder, look at the file extension on the music file that won't play. Media Center can't play files with unknown or incompatible extensions.
If you find a questionable extension, skip that file. Click once on another file with a different extension, one you know is compatible with Media Center, and then click "Open" to test if you can play that one.
Media Center will play MP3, CDA, WAV and other music file formats.
Open Windows Media Player from the Start menu if you receive a codec error while trying to play either audio or video files.
If you open the file in Media Player, the codec will download automatically.
You should then be able to play the file in Media Center.
Troubleshoot your firewall settings if a Media Center extender doesn't work.
You'll have a problem using an extender if Windows Firewall blocks it.
Go to "Control Panel" from the Start menu and double-click on "Windows Firewall."
Click on "Allow a program or feature through Windows Firewall."
Click to check "Media Center Extenders."
Click on "Apply."
Check external speaker cables to make sure they're connected if you can't hear any sound. Check the computer's volume settings by clicking on the "VOL+" icon at the bottom right corner of the main Media Center screen to make sure the volume is not turned off or down too low.
You may need to reconfigure your speakers if you're having volume or sound issues.
Scroll down to "Tasks" in the Media Center home screen and select "Settings."
Click on "General" and select "Windows Media Center Setup."
Click on "Set Up Your Speakers."
Follow the on-screen prompts to reconfigure your speakers.
Nanny
Level 3:
Genius:
  • Gateway Master 2,351 Answers
  • Posted on Dec 05, 2019
Nanny
Gateway Master
Level 3:
Genius:
Answers
2351
Questions
0
Helped
989274
Points
7262
Reason 1. The Windows Media Player may not work with some certain video files.
For example, some people would like to watch DVDs on Windows Media Player.
Reason 2. The Windows Media Player is not completely supported by Windows 10.
After the Windows 10 was released, some news you might have heard about is that Microsoft decided not to support the Windows Media Player.
Reason 3. The Windows Media Player could be just freezing .
This reason can be tricky because every system is likely to meet some freezing issue moments.
Reason 4. Probably you can only run this program as an administrator.
  • Joni Campbell
    Joni Campbell Jun 14, 2021
    Thank you for all the answers. My other slideshows will play the music not this one though
  • Anonymous Jun 14, 2021
    get vlc and end this pain.
    avoid MS MP
Videos won't synchronize from windows media player to sansa e250 mp4 player
You need to use the supplied Sansa Media Converter program to convert videos (and photos) to a format the Sansa can handle. If you don't have the SMC, you can download the Windows version here.
3answers
New dell d620 laptop won't play dvds on windows media player
Hello
You need to install a codec pack which you can get here for free:
http://www.softpedia.com/get/Multimedia/Video/Encoders-Converter-DIVX-Related/ACE-Mega-CoDecS-Pack.shtml
Hope this helps.
6helpful
2answers
Can't play on windows XP
Windows media player won't open disc, apart from the title page
2answers
My windows media player won't play and it want let me reinstall it
your current version might be outdated an not be able to reinstall because it cant be supported
http://download.cnet.com/windows-media-player/3000-2139_4-10315038.html
The latest iteration of Windows Media Player adds a lot of useful bells and whistles, succeeding in many ways as a competitor to iTunes for Windows.
hope this helps
I dropped it and now it won't work. It starts but there is a knocking noise and won't select movies or do anything.
Remove media player from CPU ("Add and remove Programs" or "Programs and Features" both under control panel), then Google Windows Media Player, free down, if that doesn't work, its most likely a hardware issue. Hope it works!! :)
2answers
The video won't play. codec is needed
You can download/ install Media Player Classic
Download the latest version of Media Player Classic (K-Lite Codec) FOR FREE
It is a small but a very fine Media Player which also installs all the required CODEC and you can play all audio - video files.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Mobiblu DAH 1500i Battery
I formatted it with windows 7 and it read "no file" even with songs on it. Then I formatted it with windows XP and it worked!
Synk issue
If it is not syncing, it is possible that the computer is not recognizing the player: Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Windows Media Player won;t sync music!
Turn off the automatic sync option - change it to manual sync, and then you should be good to go. Change to manual sync first, and then reformat.
Top Gateway Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
