My Janome 611 machine tangles the thread behind the bobbin. The hook is picking up perfectly but when it throws the loop it looks like it is not being released from the nylon protrusions behind the bobbin and getting picked up a second time by the hook as it comes around again. Could this be a timing problem? The fact that the hook is picking up the thread correctly makes me doubt it. Any suggestion?
SOURCE: singer advance 7422....won't pick
It sounds like your timing is in need of adjustment and unfortunately you need special tools and know how. So, you have to take it in for service.
SOURCE: My machine is new and
You have described your problem just fine. Have you just changed the needle in your machine? If so, check it is in the right way, you want the flat shank to the back.
The needle has a scarf (scoop out) at the back - if it is facing to the front then the rotary hook (bit that goes around the bobbin and catches the top thread) can't catch the needle thread behind the needle.
Also check needle is fully up into the housing, this could also cause problem.
I'd suggest that you visit www.sewingabout.com and check out the pages on general sewing machine use, care and threading up, lots of helpful pictures and information which may be of assistance to you.
If it isn't your needle backwards (very easy to get wrong, happens all the time), then the timing could be out, which isn't so easy, but as its new I'd be very suprised if this was the fault. Just check needle, make sure top and bottom threads are threaded correctly and have another go. Also, remember to turn flywheel towards you.
Hi. Usually this is due to a wrong needle or your needle not being set correctly. Do you know if your patcher is a 29k? or?
http://www.parts.singerco.com/IPinstManuals/
There are various manuals at that link... hopefully your patcher is there. good luck
