Our whirlpool jacuzzi button won't work but you can hear it click ...and when it does turn on itself it will only run for approx a minute but it's maintaining the water temp
Sounds like you may have a circuit that is bad in the control box under the tub.
Very unusual for that type of issue unless there is a problem on the circuitry.
Call a technician to have them trouble shoot it for you. It may need to be replaced. Those are not usually an item that is fixed.
When you push the air button down it sends a column of air to the air switch located in the motor. When there is not enough air sent by the air button on the top of the tub it will not make the air switch "latch" in the closed position and means you need a new air button. In your case the air button is sending enough "air" however when the air switch is not "latching" in the closed position that means the air switch is bad and needs to be replaced. Most air switch's can be replaced with a TBS-310 US Parts Center
In my case I took the motor out and used a screw driver to turn the impeller in the front of the pump and the fins inthe back. Put it back together and it worked. I then used 2 tablesoons of dishwashing detergent and 1/2 cup bleach and ran it for 20 minutes to clean and degrease the impellers
I bought a new house and I have a jacuzzi bathtube . and all the sudden stopped working .. where or how I can locate the pumpe ? the only thing I see is the button to turn it on or off and now it does'nt go on ?!! I checked the circute praker and everything seems okay to me.... help please.
