Burner seems to cycle on and off before food comes to full temperature.
They cycle off once they have reached the temp that you set, then come back on to keep that temp, my suggestion is increase the set temp.
Testimonial: "Thank you for your response but . . . . even on max temp for boiling water, the burner cycle off for up to 30 seconds before coming on again. As I said, takes forever to boil water for pasta! <g> Switch or Burner? Whatchathink?"
SOURCE: changing the surface burner spark electrode for GE stovetop
Schematic -
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=JGP326WEV1WW&productCategoryId=0121050&brandId=0432&modelName=GAS-COOKTOP&diagramPageId=00001&componentDescription=COOKTOP&documentId=10053061&backToLink=Return%20to%20Sub%20Components%20list
SOURCE: My electric stove top burner only works on high
This is for the glass top units. well i'm not sure if your problem is with your large or small single burner or the large expandable burner. If it's the large or small single burner replace the burner and if it the expandable also replace the burner. If you have a coil burner replace the infinite switch. Good luck hope this helps you.
SOURCE: LIGHT STAYS ON FOR HOURS BUT THE TOP HAS COOLED
if its going out, its probably ok
its not a light indicating the burner is on, rather that the glass is abcove 100 degrees and still not safe to put something on
2 hours is a bit long but it depends on how fst the surface can cool of
you can test this by trying to cool it off faster with a fan ans see what happens
Testimonial: "THANK YOU FOR GETTING BACK WITH ME QUICKLY YOU GAVE ME SOMETHING TO CHECK FOR AND I WILL LET YOU KNOW HOW IT WORKS"
SOURCE: Electric ignition for one burner on counter top ge
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
SOURCE: ge profile electric counter top stove
I did not receive instructions with my G E Profile cook top Model No. 80030750434). There is a build up on the elements which I am having problems removing. Should the top be scraped while the stove is hot or cold? What is the best cleaning product to use?
