SOURCE: Whats the best way to drop the gearbox & transfer case?
remove the carpet on the floor, remove the gear shift lever as well as the 4wd shift lever, remove the drive shaft (both) remove the bell housing bolts, remove the starter, place a hydraulic lift jack below the gear box , then remove the wiring connectors , then remove the cross member , then pull the gearbox out from its positin, drop the gearbox very carefully, when gearbox is on the floor, make sure its sittin on a up right position so it dose not spoil any of the elctric connectors especially the reverse light switch...(that seems to be the easiest way to remove a manual land cruiser gearbox) hope that wil help....
SOURCE: water in the radiator reducing everyday in mitsubishi pajero IO
If you do not see any obvious leaks or puddles under the car, you may have a head gasket leak. A compression test will find this. Any good mechanic will be able to do this test.
