Carnt buy vc coins on nba 2k 13 status code 80153003 appears for xbox
SOURCE: disktray keeps coming out on my xbox 360?
I have a XBox360 to and she did the same thing a while ago, the disk plate must be blocked or the eject button must be shorting out, make sure that the sides of the slot are clean and that there are no debris at all, and if you have a chance too take a look inside the console make sure that all cables are connected to the driver properly.
Hope this helps!
SOURCE: my nba 2k 10 [360] always freezes right when it
there might be some problem with your disk or game played either it might be from a unauthorised site so it freezes ...if nothing happen with other disk u can check with the cd u used..u can even try this site to solve the problem..
SOURCE: my xbox makes this sound
XBOX 360 repair guide
available that covers this problem and also all other common XBOX problems. You
can get your copy XBOX 360 Repair Guide, you can download it and get help to
fix your console.......
Click here to download repair guide
When you're in franchise mode, if you go to Edit Player, you can adjust the salary that you pay the player, and therefore, get more money.
At the begging of a season you get 10 new drills. Before you start your new drill, subtract on point from you 3 point stat, which gives you around a 1000 skill points to spend on anything else, then complete a shooting drill by attempting only 3s to get your 3 point attribute maxed out again. This is a simple way to get extra skill points. You can do this anytime you get a drill.
Enter the following codes by choosing "Features," "Extras" and then "Codes."
