Question about KitchenAid KSM500PSSM Silver Metallic Pro 500 5-quart Stand Mixer
I have recovered my kitchenaid pro 500 mixer that was stolen, but the serial numbers have been removed. is there any other place to look
Is there any other way to find a serial number on a Kitchenaid pro 500 other than the stickers
  • KitchenAid Master
  • 1,343 Answers
The sticker is the only number that they have here in NZ. I don't know how they operate in your country but here if it is registered we can just ask the distributor for the serial number of the products that we have registered under our name. Our database is searchable by customer name or serial number.
Posted on Dec 01, 2013
SOURCE:
SOURCE: My KitchenAid Mixer won't turn on
Check your Brushes  or bushings or whatever there called ) those little black things on the side of your mixer above the speed selector and the up/down switch) Check to see if they have started to wear down then i recommend taking it in for service. Good Luck!
Posted on Dec 07, 2008
SOURCE: Kitchenaid K5A mixer 10 speed only runs on fast, no slow speed
Pull the back off and there will be two screws at the top of the Speed Control Plate and a 3rd screw at the bottom. Tighten the top two screws down. bakerboy49203@yahoo.com. Let me know if it works.
Posted on Mar 21, 2009
  • 297 Answers
SOURCE: Age of Kitchenaid K5A mixer
1980
Posted on Jul 15, 2009
hslincoln
  • 235 Answers
SOURCE: Kitchenaid mixer. Top is loose so it bounces when
Hi MJANKOW520. I?m going to assume your KA mixer is a ?Tilt-Head? mixer. You don?t say specifically. Based on your description of the symptoms you mixer exhibits, I would say that your head locking mechanism (or a component) of it is either broken, worn or loosened due to normal wear and tear and need to be readjusted (or repaired) for it to keep your mixer head stationery. The inspection and troubleshooting of the inside of your mixer is a DITY capability, particularly if your mixer is out of warranty. Just be sure to have the Parts List manual on hand. If you're lacking one, you can download a PDF version from the KA website: http://www.kitchenaid.com/flash.cmd?/#/page/home. Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in your case, try K45SSW, and select the file listed under Parts List (check to see it this matches your mixer model). This parts list manual provides an exploded view for the disassembly and reassembly of your mixer, along with all the part name and numbers. Turn to page3, titled: Base and Pedestal Unit. You?ll want to focus on Illus. #9, Link & Lever Latch assembly, which locks the mixer head to the pedestal when run your mixer. Check to see if something is just loose, exceedingly worn or broken. If something has broken, you can order replacement parts and install yourself. As far as parts go, here are four potential vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com. Prices for the same part can vary widely between vendors, so do your comparison shopping. Once apart you can check for any other unseemly wear and tear on other mixer components. It can be messy but quite gratifying to diagnose and repair your mixer yourself. Finally, here's a link to an excellent site that details the disassembly and replacement of a mixer's grease, which might be helpful, too. http://www.foodonthefood.com/food_on_the_food/2009/04/how-to-repair-a-kitchenaid-mixer-yourself.html If you feel this is beyond your capabilities and would be too difficult to do yourself you can take your mixer to a local small appliance repair shop and have them troubleshoot and fix your mixer. KA Customer Care can provide you with the name and phone # of the closest authorized KA repair shop in your area or you can do a Online web search, but be sure to get at least three estimates before deciding to commit to one repair shop. Good luck. I hope this helps. Howard, Burke, VA If this solution has helped you, please rate it, thanks! - hslincoln
Posted on Dec 02, 2009
hslincoln
  • 235 Answers
SOURCE: How do I replace the Speed Control Knob on the K5 Kitchenaid Pro
Hi PETER, Happy New Year! Your Speed Control Knob can be replaced quite easily (OK, maybe with a little effort) by yourself, if you are a DITY type person, feel adventurous, and your mixer is not under warranty.
Before you start taking your mixer apart, be sure you have the Parts List manual on hand. If you're lacking one, you can download a PDF version from the KA website at: http://www.kitchenaid.com/flash.cmd?/#/page/home.
Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in your case use KSM50P (Your K5SS mixer falls within this manual), and select the first file KSM50P.pdf (438.31 KB) listed under Parts List (4) and then check to verify this matches your mixer model.
Your speed control assembly is attached to the bottom of the top part of the mixer’s head (or Illus. No 1, Gearcase Motor Housing, on pgs 4 & 5).
Turn to pages 6 & 7, titled: “Motor And Control Parts”, which provides an exploded view for the disassembly and reassembly of your mixers electrical components, along with all the parts. Locate lllus. Nos. 1, 2, 3, 4 - Pivot screw, Spring Washer, Switch Lever and Stud, and Control plate spring, respectively, which is the speed control handle assembly and Illus No. 5 and 6 - Speed Link & Cam and Flat Spring. Carefully inspect these parts to see if they have not come loose, particularly the Pivot Screw and Spring Washer. Also check to see if the Speed Link & Cam hasn’t shifted from its position. You should be able to see if something just needs to be tightened or if parts need to be replaced.
Also, with your mixer apart you can check for any other unseemly wear and tear on the gears, etc. It can be messy but quite gratifying to diagnose and repair your mixer yourself.
As far as parts go, here are five potential vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com; and Grainger.com. Prices can vary widely between vendors, so do your comparison shopping.
Finally, here are some links to several excellent websites that detail the disassembling/reassembly of a KA Mixer. The mixers displayed in the links may be different than your KA model, but the principles are the same.
Between these three websites and their excellent pictures and descriptions and your Parts List manual, you should now be able to completely disassemble and reassemble your mixer, should you decide to go that route.
If you feel this repair is beyond your capability, then I would seek out a local small appliance repair shop in your area. KA Customer Care can give you names of local KA authorized repair shops in your area, but you can also do an online search to supplement what KA may provide you. Call to explain your circumstances and find out their hourly rate and get an estimate of what they think it would cost to repair your mixer. Also, always obtain three or more estimates – do some comparison shopping.
Good Luck. I hope this helps. Howard, Burke, VA
If this solution was helpful, please rate it, thanks! – hslincoln
Posted on Jan 04, 2010
What serial number mixers have a plastic gear cover
All of the new style that are made after 2002 0r 3 that are bowl lift models and up untill 2008, They no longer make the plastic as it could not handle the work load all are made now with a cast aluminium cover. Hope that helps
Oct 10, 2014 | KitchenAid Pro 600 Stand Mixer KP26M1X-...
Year of manufacture
  • The K5SS was manufactured from 1978 to sometime in the 1980s (don't know if it made it into the 90s). Hobart sold its Kitchenaid division to Whirpool in 1982. If yior mixer has the Hobart logo on it then it was from 1978 to 1981 9 or 2. If it is identified only as Kitchenaid then it was made after 1981.
Jun 01, 2014 | KitchenAid K5SS Heavy Duty Commercial...
What year wasmy mixer made
The ksm90 mixer has been being produced for many years, the only way to find out when your mixer was made is to call KitchenAid with the serial number. They should be able to let you know when the mixer was made.
Apr 09, 2013 | KitchenAid Food Mixers
Where do you find the serial number for a 5 quart glas bowl for the Artisan mixer
The serial number for all KitchenAid mixers is located under the base of the mixer. You will need to carefully tilt the mixer over, and underneath the mixer you will find a label with the model number and serial number.
Feb 16, 2013 | Kitchenaid 5 Quart Glass Bowl Artisan...
I put 240v to 110v motor.will it be just a new motor?
You probably blew out the soft start circuit. You can buy new ones at appliance parts stores if you are handy.
Jul 01, 2012 | KitchenAid KSM500PSER Empire Red Pro 500...
I need a serial number on model ksm158gbca kitchenaid mixer
Not usre i understand the question. The serial number of your item should be on the machine, sometimes on the bottom.
Mar 11, 2010 | KitchenAid Food Mixers
We just bought a Kitchenaid Pro 500. It was not
Hi JBKRIEGER, Happy New Year! Yes you can download both your Owners Instruction Manual and Parts List Manual from the KA website at: (http://www.kitchenaid.com/flash.cmd?/#/page/home).
Click on Customer Care>Locate Manuals& Guides> and enter the 6 character model number and then select the appropriate files under Owners Manual for your Instruction and Recipe manual and the file under Parts List for your parts list manual.
The Parts List manual provides an exploded view for the disassembly and reassembly of your mixer, along with all the part names and numbers. (Definitely check to see it this matches your mixer). You may not need it now, but if your mixer is out of warranty and you want to attempt to troubleshoot and fix your mixer yourself if something goes wrong with your mixer, you’ll definitely need that parts list manual.
Good luck with your KA mixer, Howard, Burke, VA.
If this solution was helpful though, please rate it. hslincoln
Jan 10, 2010 | Food Mixers
KitchenAid KSM500PSSM Silver Metallic Pro 500 5-quart Stand Mixer Logo
88 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
CJ C
CJ C
Steve Allison
Steve Allison
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
