Question about Roper REX4634KQ Electric Dryer
Dryer does not get hot enough to dry clothes Roper REX4634KQ1 Electric Dryer
When I use my dryer the dryer does not get hot enough to dry my clothes. It feels like it gets warm but not hot enough to dry clothes. I have to run clothes through 2 cycles and even then some things are still damp.
Any ideas or replacement part ideas??
  • 13 more comments
  • Anonymous Nov 06, 2007
    dryer does not get hot enough to dry cloth
  • Anonymous Feb 01, 2008
    heater coils do not fully light up. The majority of the coil glows but there seem to be some "dead" spots. This is when the switch is on "hi" or "cotton" selection which is the hottest setting. The coil test good for continuity. Could this still be a faulty coil or something else?
    The switch for the fabric settings checks out as well as the thermostats.
    Any suggestions.
    ps; Before this the coil was not coming on at all. The heater relay was bad. I learned about this on the web. The manual I bought from Sears
    said nothing about this possibility!
  • Anonymous Feb 06, 2008
    I have a Hotpoint Heavy Duty dryer and have the same problem. Dryer seems to get warm but not hot enough to dry clothes. I also need to dry 2 cycles.
  • karent2008 Feb 16, 2008
  • Anonymous Mar 19, 2008
    mine is brand new + has the same problem
  • ishot2pac Aug 28, 2008
    Sounds like we all have the same problem with no solution, i have amana gas dryer that don't get hot enough, i have to dry my clothes in 4 cycles
  • Anonymous Dec 02, 2008
  • mrshamiltonn Mar 15, 2009
    Where is the heating element or thermostat located in the dryer ?
  • jerry kasper May 11, 2010
    i have a gas dryer that recently stopped heating properly, it takes acouple of times before the clothes dry,why?
  • Anonymous Mar 19, 2014
    The dryer doesn't get hot enough to completely dry clothes
  • Anonymous Mar 20, 2014
    the clothes do not come out as dry, or warm, as they did last week
  • Anonymous Mar 22, 2014
    noise while running but clothes still drying
  • Anonymous Mar 23, 2014
    Dryer feels hot but most of my clothes are not drying. What could the problem be
  • Anonymous Mar 26, 2014
    My Amana electric dryer wont get hot enough to dry my clothes the first time. I have to run each load of clothes twice. I am very knoledgeable when it comes to fixing cars but dryers are a whole nother ball game to me.
  • Anonymous Mar 28, 2014
    The dryer doesn't seem to get hot enough when drying the clothes.
  • 75 Answers
Either the heater element is breaking or is loose and getting only 110V instead of 240V.  First I would check the wall outlet with a voltmeter for 240V between Line1 and Line2.  Also check the connections and continuity for the heater element.
Posted on Oct 11, 2007
Check for lint in fan housing , these roper dryers tend to do this , causing loss of air flow across element
Posted on Nov 23, 2009
    Problem Solver:
  • 12 Answers
If your element is operating and drawing about 20 amps when on, your problem may be the thermostat (temperature dial) or the moisture sensor (if applicable).  My dryer has 2 heating elements.
Posted on Oct 15, 2007
2 Suggested Answers
SOURCE:
  • 10 Answers
SOURCE: Dryer does not get hot enough to dry clothes Roper REX4634KQ1 Electric Dryer
The vent may be stopped up, or the vent hose crimped so the air cannot escape, you can check the air flow at the vent on the outside of the house while the dryer is running.
try cleaning the vent and the lint screen with a vacuum cleaner, you may need to replace the vent hose, this should solve the problem
Posted on Jun 02, 2009
Dryer model Roper RED4340SQ1 rmy heater don't stay hot all the time during a drying cycle is it normal or i need to change it
You may want to do a thorough tuneup on your dryer. I worked on a couple and wrote a pictorial on it. ROPER DRYER TUNE-UP
My Home movie of a Roper dryer with a heat problem:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 06, 2012 | Roper Dryers
Whirlpool dryer does not get hot enough to dry clothes.
Clean/repair the dryer vent. If the airflow is restricted the result is the one you just described.
Good luck,
Vlad
First Choice Appliance
Apr 20, 2010 | Roper REX4634KQ Electric Dryer
Dryer (Roper, electric) won't heat
Its probaly gone open circuit, however there is a thermistor that prevents it shorting out, you need to locate it and test it with an ammeter
Mar 25, 2010 | Roper REX4634KQ Electric Dryer
Roper electric dryer. Clothes not drying. Temp ok/timer not?
I would supect a faulty high limit thermostat. This small round device is mounted to a metal plate and attached to the internal ductwork. It can be tested using a multimeter or ohmmeter. Test for continuity. It should have none. Hope this helped and best wishes.
Aug 11, 2009 | Dryers
Dryer has some heat but is taking a long time to dry clothes
This type of problem can be caused by a partially burnt heating element, a blown thermal fuse, or a faulty high limit thermostat. All of these components can be checked using an ohm meter or multimeter. Sure hope this helped and best wishes.
Jul 27, 2009 | Roper REX4634KQ Electric Dryer
Jun 02, 2009 | Roper REX4634KQ Electric Dryer
Warm air but clothes not drying
Make sure u have seleced the high heat setting..The fact that it is heating more or less indicates that the element is o/k.
Check and clean any filter(s) that u can see,it is more likely to be a thermostat problem than anything else. and there are at least 2 of them, also check line voltage is correct.
Plz rate this solution.
thanks.
Jan 01, 2009 | Roper REX3614KW Electric Dryer
Most common cause of this is a clogged venting going to the outside to test this remove the vent from the back of the dryer and run a load if it drys ok them you know you have a venting issue and will need to be cleaned out if not plz repost and we can look deeper into it
Jul 15, 2008 | Roper REX4634KQ Electric Dryer
Dryer not drying
Check your lint filter. Put it under running water to see if the water goes through it. Chances are it is clogged up. Wash it and put it back. Should do the trick.
SGt 48
Jun 18, 2008 | Roper Dryers
Roper REX4634KQ Electric Dryer Logo
3,935 people viewed this question
Top Roper Dryers Experts
Craig Butler
Craig Butler
Marvin
Marvin
Dennis Boxerman
Are you a Roper Dryer Expert? Answer questions, earn points and help others
