James Gray Posted on Nov 30, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Technics SL-D33 Channel drop.
Lost left channel on my technics SL-D33 Right channel sounds good.Removed it from receiver and hooked up a Dual CS 528.Both channels work fine.
Grubhead
Level 3:
  • Technics Master 5,755 Answers
  • Posted on Dec 01, 2013
 Grubhead
Technics Master
Level 3:
Answers
5755
Questions
Helped
1662568
Points
11417
There's nothing wrong with the turntable then. It's your receiver that's the problem. In order to hear a magnetic cartridge it has to go via a pre-amp. It's this pre-amp that has failed in your receiver. It's only used by a turntable so wouldn't affect anything else. You should be able to trace this pre-amp by following the turntable socket wires. It will probably be a small IC that has failed. If you look up the number you should find it.
3 Related Answers
Anonymous
  • 515 Answers
  • Posted on Jul 12, 2008
SOURCE: Hum on right channel
It doesn't really sound like this tech knew what he was doing. He probably connected the ground wire incorrectly. I would also suggest opening up the tonearm base section, and checking to see the work he did. Perhaps he did not solder the RCA leads correctly.
If all is good, then there are only 2 other things which may cause this... 1) Tonearm, 2) Cartridge. You'll have to check those 2 out.
FYI, I work on 1200s for a living, so I know these machines inside out.
- Davis
DIGITAL ANALOG THERAPY
www.REPAIRNYC.com
www.1200s.com
micmor100
Morne Olivier
  • 265 Answers
  • Posted on May 06, 2009
SOURCE: Technics SL1500 will not connect to new Sony STR-DH100 receiver
Unfortunately, a turntable runs on a different frequency, and if there is no button at the back of your receiver to change the frequency setting on that channel, it wont give you any sound. the best bet is to go to your music store and purchase a small DJ mixer. connect that to your receiver, and run the turntable through your mixer. the mixer will have the neccesary flip switches and "ground" connections
Grubhead
Grubhead
  • 5755 Answers
  • Posted on Mar 20, 2010
SOURCE: Only one channel plays.
If you disconect the wires to the cartridge and with deck plugged in to the amp and switched on, you can touch the ends of the wires with your finger. Though there are four wires, only two should produce a buzz, one in the left, one in the right speakers. If you get a buzz in each channel, the rest of the unit is working fine and you have a faulty cartridge or a poor connection to it. If one channel remains dead, then you have a problem in the wires to your amp or an internal fault inside the deck. If internal I suggest you remove the bottom of the turntable and have a look around.
Can i hookup a television to my receiver for sound
Yes. You can hook it up using a digital coax or optical cable. Use can also use old stereo, analog, left and right channel audio. Use any audio input on your Technics, that will accept any of the inputs above.
1helpful
Technics sl ch570
pls. try switching the speakers, if the sound switch from left to right or right to left , one of your speakers has an open circuit. check the wire for any open link or check the speaker for an open voice coil.
Poor sound quality from a technics SL-D210
Generally either a faulty connection to a lead or cartridge. Or a faulty Cartridge. If you switch the left and right channels of the phono leads the missing sound should move to the left and the right come to life. If it does not then there's a fault in the magnetic cartridge pre-amp in your amp.
1helpful
Technics 1310 turntable has left channel (white
There are just two causes, one is the preamp, which can be easily checked by putting the right channel jack in the left terminal. If the sound is normal, then it's likely that the cartridge in the deck is bad, or some wire is loose. However if the sound is still poor then the magnetic cartridge preamp in the amp has a fault. These are normally a single IC, which will have failed. Find the preamp by tracing the wires from the imput socket to the PC board, which may be alone.
Technics SA-810 receiver-no sound
For the question at the top you most likely blew your computer chip on the Technics sa 810, we have 2 of these receivers and one lost it left channel and the green auto light went out, we have taken it to several places and they ended up having to turn down the power. now it is working great sounds the same just needs more volume level, but it ended up costing $500 CAD, you can't get the auto to work any more, you will most likely need a new stereo, The Technics SA 810 is an awesome receiver, good luck fixing it
- Davis
www.REPAIRNYC.com
www.1200s.com
2answers
Technics SU-G91 Left channel bad
Did you ever find the solution to the left channel issue? I have the same problem with mine.
Technics SA-AX720
Look for lossing solders points or bad conections. Start to look on those components of hi wattage and components to get hot alot, those are the most common to have weak solders spots.
Also some equipment need to be clean because the dust can make problems.
good luk.
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Kolbrun...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
