Hamilton Beach 40870 Electric Kettle Logo
Jack Rutt Posted on Nov 30, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Auto-shutoff stopped working
Is there an inter-lock mechanism on the lid so that the auto-shutoff does not work if the lid is not closed? I recently had to take the flipper part of the lid apart to glue the small catch part of the mechanism. When I put it all back together, the catch worked fine, but now the auto-shutoff does not work. I used to observe this when the flipper lid was not closed.
  • Jack Rutt Dec 01, 2013
    Julian's post of February 2008 was spot-on. The kettle uses steam pressure to trigger the auto-shut off. When I repaired the flipper lid I also removed the screen to clean the pot with white vinegar. I boiled the water WITHOUT the screen filter in place it never did an automatic shutoff. After reading Julian's comment I tried it again with the screen in place and it worked perfectly! Thanks, much!
mikadot
Level 3:
  • Master 2,113 Answers
  • Posted on Nov 30, 2013
mikadot
Master
Level 3:
Answers
2113
Questions
0
Helped
465745
Points
5959
It just has to do with a thermal cutoff that it got hot enough
Testimonial: "This comment by "mikadot" was not helpful, however, Julian's post of February 2008 was spot-on. The kettle uses steam pressure to trigger the auto-shut off. When I repaired the flipper lid I also removed the screen to clean the pot with white vinegar. I boiled the water WITHOUT the screen filter in place it never did an automatic shutoff. After reading Julian's comment I tried it again with the screen in place and it worked perfectly! Thanks, much! Jack"
Eppendorf centrifuge model 5702: lid not does latch/lock after emergency release.
If the lid of your Eppendorf centrifuge model 5702 is not latching or locking closed after the emergency release, it is possible that the locking mechanism is damaged or misaligned. Here are some steps you can try to troubleshoot the issue:
  1. Check the alignment of the lid: Make sure that the lid is properly aligned with the base of the centrifuge. If it is not, the locking mechanism may not engage correctly. Adjust the lid as needed and try to latch it closed.
  2. Inspect the locking mechanism: Check the locking mechanism on both the lid and the base of the centrifuge for any signs of damage or wear. If you see any damage, you may need to replace the locking mechanism.
  3. Check the safety interlock switch: The safety interlock switch is a small button located on the base of the centrifuge that is depressed when the lid is closed. If this switch is not working correctly, it can prevent the lid from latching closed. Check that the switch is functioning properly by pressing it with a small tool while attempting to latch the lid.
  4. Contact Eppendorf customer support: If none of the above steps work, you may need to contact Eppendorf customer support for further assistance. They can help you troubleshoot the issue and provide advice on how to proceed.
Auto shut off needs adjustment
At the end of play, the tone arm moves a small piece into the revolving gear that operates the shutoff process. If the tone arm remains in the completely played position, this mechanical connection is not working.
2answers
Automatic door locks
is i lockingt after you start it... and does it relese when turn off
1helpful
The machine went through a cycle and stopped in the middle of a rinse cycle. Trying to restart, the red lock symbol kept lighting up and would hear the lid lock mechanism activate. Tried switching machine...
if the lid lock is activating then testing it electrically wont help. you say that the lid lock is working when you manually put the lid lock in the closed position., is that correct?if it is, does the machine work on the spin cycle once you have manually activated the lid lock? have you checked for damage to lid? please reply 4 more help.
Accidentally closed trunk without letting auto
is the trunk lid latched at all
or is latched but not tight
Won't shut off
the auto shutoff has failed, either because its dirty and needs to be cleaned or it may actually be faulty. Clean or replace the auto shutoff mechanism.
Car won't start after using Auto headlights on 2005 Lexus LS430
The trunk should auto close when you manually lower the lid to the almost closed position, but it is NOT designed to open up fully when you hit the trunk release on the key fob, nor when you open the trunk manually using the touch sensitive button under the lip of the trunk.
4helpful
2answers
Rowenta DM880 Auto shutoff - Shuts off too frequently
This is a problem with a lot of Rowenta irons. It is the auto shut off that is not working properly and the only way to fix it is to have it disassembled and the switch hardwired to be on whenever the iron it plugged in. It is a thermal metal switch and it just stops working and then the iron will not turn on and the yellow light blinks.
Top Hamilton Beach Kitchen Appliances - Others Experts
Mike Cairns
Mike Cairns
deton8 von Splosion
ADMIN Eric
ADMIN Eric
Are you a Hamilton Beach Kitchen Appliances - Other Expert? Answer questions, earn points and help others
