Magellan Roadmate 1200 Car GPS Receiver Logo
Posted on May 09, 2009
Roadmate 1200 will only turn on from power button. Will not turn on when you turn ignition on?
Anonymous
Level 1:
  • Contributor 3 Answers
  • Posted on May 31, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
633
Points
Magellan roadmate 1200 will not turn on from button
4helpful
2answers
Need to update Magellan RoadMate 1200
Steps to Update Magellan Roadmate 1200 GPS :
1. Go to official website of Magellan and choose "support" option. After selecting the support you will find the various options. You have to select "Manual and Software Update".
2. Choose your product from the drop down the menu and select Roadmate series. A pop up will display on the screen and choose I want to download this update.
3. Hit the "Download Now" button.
4. Checkout every connection under "Redesigns and Maps" to buy Latest Magellan Roadmate Gps Update . "Add the lives maps which are available to your Cart," at the time of proceeding to the "Continue to Checkout."
After completing the process you will get an email from the Magellan. It will later to download the Update on the SD Card itself.
UNIT WILL NOT TURN ON. IT WAS STORED WITHOUT TURNING THE UNIT OFF-POSSIBLY. I WAS ABLE TO PROGRAM A ROUTE-CANCELLED THE ROUTE ANDIT HAS NOT WORKED SINCE. I PRESSED THE RESET BUTTON
plug it in to a known good charger for a few hours, then press and hold the power button for up to ten seconds.
let me know if you need more help or info
Bill
Standing Member of G.O.T.
My magellan roadmate 1200 will not turn on
make sure green light is on if using the car charger and let it plugged in for awhile, then hold the power button (up to ten seconds) until it starts..
if you tried charging it with both house charger and car charger and tried to start it like i explain and it still will not start, its most likely a bad power port which is very common with this model and many other magellan models.
2helpful
plug it in to either the home charger or the car charger for a few minutes,(is the green light on, on the car charger) then press the power button for up to 15 seconds.if that fails, try a hard reset. little pin hole on the side(use a paper clip) if that fails you might have a bad usb connector.
Jul 23, 2009 • GPS
10helpful
3answers
Where can I download free maps for my Magelllan RoadMate 1200?
go here //downloadanystuff.org/ put your download query and search
I just got a Magellan roadmate 1200 over the weekend from a friend and when I plug it in it loads to a screen that says the usb is connected follow pc instructions
The USB must be for charging the unit and downloading updates when it becomes available. You have to unplug the USB and use the battery power to put in addresses .My 1200 does the same.
Roadmate 1200
PRESS AND HOLD THE POWER BUTTON, AND THEN PRESS THE RESET BUTTONS, AND THAT SHOULD RESET THE UNIT TO OEM DEFAULT SETTING AND THE PROBLEM SHEOULD BE FIXED.
Top Magellan GPS Experts
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
Are you a Magellan GPS Expert? Answer questions, earn points and help others
