Coffee Makers & Espresso Machines Logo
Lance Hill Posted on Nov 30, 2013
Annoying squeak when lid is raised - Coffee Makers & Espresso Machines
1helpful
Dehumidifier squeaks when running
Disconnect it, (DO NOT REPAIR WHILE CONNECTED), remove outer plastic casing (screws), lubricate moving parts with a little WD40 or similar. Re-assemble.
If you can get to the part that's squeaking with a long tube you could try spraying silicone lubricant spray on it without disassembling.
My printer model 5700 desk jet is squeaking
Often times dust or paper debris becomes lodged around the printer feed wheels. Use a can of compressed air to throughly blow out all areas accessable. If the printer is older it is usually cheaper to replace it than trying to repair.
Very annoying squeaking / creaking during agitation
sounds like trnsmission and brake assembly they are not cheap. you can see one at www.repairclinic.com scroll down to the red(100) click it and look for part number 279566.
Squeak
PHOTPSMART PRINTER 4180 MAKES SQUEAK SOUND WHEN SCANNIN
4helpful
Squeaking
the squeak is coming from the drum unit. If you take out the drum and rotate it by hand it will most likely give you the same noise. you may be able to stop it by pouring some toner on it, but in reality it is more annoying than a problem.
there is a blade that scrapes off excess toner from the drum, it is slightly dry and causes the squeaking, technicians usually use a special powder that looks like baby powder to "lubricate" the blade, and stop the noise.
Top Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Sulejman Sulejmani
Sulejman Sulejmani
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
