SOURCE: fridge not cooling
Most of the time on a whirlpool the problem is the relay on the compressor sometimes called the start device. I would replace that first. If you need help finding the part let me know. I will need the complete model # from the sticker inside the fridge section. You can look it up with diagrams at http://www3.sears.com/.
SOURCE: not cooling
The clicking you are hearing is your overload on your start system sounds like your compresser start ststem is out..or your compresser is locked up the only way to tell is to ohm out the compresser idf you dont have a meter you can install a start kit like a Supco Pro41 or a RCO410 or a factory replacement and see if it starts up the compresser.. Have you cleaned the condenser at all ??? although this will not fix the compresser it can be a cause of overheating..The part Number you need is a 2188831 for the factory replacemenet ($22.56)the supco parts part number SU RCO410 ($15.00) the Pro41 is part #
SU PRO41 ($17.97) you can get them at your local parts house they are all easy to change or if you dont have a parts house close you can oder it on the web at www.apdepot.com Hope this fixes ya
SOURCE: panel between fridge and freezer very hot and no sound at all
Dont know about the noise prob. but I can help with the over heating cabinet. Your condensing coil is dirty and needs cleaned. it is located under your refrigerator or behind the back panel. You should use a brush and vac. it out. Air must travel through the tubing freely in order to cool properly. It should be easy to find following the tubes coming out of your compressor.
SOURCE: Clicking noise coming from whirlpool refrigerator
The clicking sound is a relay called PTC relay. You need to replace it. First be sure to unplug frig. Remove the cardboard cover that covers most backs of the frig units. Remove the plastic cover that is on the side of compressor. It is held on with a metal clip. Now you should be able to see the relay pry the relay straight off. note the wiring and position of relay. Only three prongs on compressor. Go to a parts house for appliance's and with your make and model number should be able to get a new one. Let me know if you need any more help. ken
SOURCE: Whirpool fridge is warm, freezer is working
Check the back wall of the freezer compartment for ice buildup. Sounds like you have a defrost issue.
