The screen is black. It sounds like its starting up but nothing shows up on the screen. I plugged it into my tv and there was still nothing. Help?
please reply if it helps/ doesn't:
http://forums.toshiba.com/t5/Video-Display/My-Laptop-Screen-Went-Black/td-p/110985
Nope didnt help. :(
Well, if that doesn't help, call Toshiba( number corresponds to your country).
Here you can find help on their website:http://www.toshiba.com/tai/support.jsp
SOURCE: We went to use our Toshiba L305D laptop. All
try to remove the battery fact then open it.. if the same problem..
check the inverter of your pc.. try ot use safe mode. restart your computer then press f8 select safe mode
SOURCE: i have a toshiba satellite L305d-S5934 laptop and
Look carefully at the screen, you should see some very faint images while its booting up. IF this is the case you need to replace the inverter.
SOURCE: How do I clear the Bios password on a toshiba
There is no backdoor password, you'll have to take it to an authorized Toshiba repair center.
You can find one here.
They usually charge about 100 to remove the password, BUT if you keep insisting that you didn't set the password they'll probably remove it for free shhhh ;)
SOURCE: my toshiba l305d-s5974 will not
Hello.
Boot your system to Safe Mode (press F8 repeatedly). Go to System Restore and choose a date when your system worked OK. Note: with System Restore, everything, including your documents and other files you saved on the hard drive, will roll back to that date.
Hope this helps.
SOURCE: When I turn on my
You may find the memory is faulty. I don't know why they fail but I have had a few. The microprocessor requires memory to "build" the programme and screen.
Try replacing it with a known good and similar specification memory.
Hiope this helps.
