The biggest advantage of Holographic Sight over red dot is that prevents parallax distortion.
That is if your eyes are not properly aligned with sights in a red dot sight you will not hit what you are aiming with your sight, as you will not be looking parallel to the barrel of the weapon. This problem increases with the range of the target.
Holographic Sights, however, uses laser to produce a holographic reticle, which is not very prone to parallax errors.
However, there must be something which keeps Red dot in demand.
Please reformulate your question: Manufacture date and value of what, specifically? An Eotech Holographic Weapon Sight Md: 516A651 might cost about 470 US$
You'll need to shim it. Use 35mm film strips, piece of plastic,electrical tape for thicker pad until you can get close to zero with sight set to middle of it's travel.
Either the scope is damaged or a screw is missing.
Contact Bushnell below:
United States Bushnell Corporation 9200 Cody Overland Park, KS 66214-1734 Kansas City area - (913) 752-3400 Consumers - (800) 423-3537 Dealers - (800) 221-9035 Fax - (913) 752-3550 Canada Bushnell Corporation of Canada 25A East Pearce St. Richmond Hill, Ontario L4B 2M9 Local Phone - (905) 771-2980 Other - (800) 361-5702 Local Fax - (905) 771-2984 Other Fax - (800) 661-3254
It will test the condition of the batteries. Turn the sight on to its brightest setting and leave it for 2-3 minutes. Then while looking at the red dot, press the battry icon button and hold it in. If the image does nothing, you are good to go. If it starts flashing, then you have less than 20% left in the batteries.
