I am trying to use the HDMI port of my LCT2785TA with a Panasonic DMR-EZ47V. The TV shows no signal, not supported, with 480i or 480p in the top left corner. I have tried the DMR with another TV and the HDMI port works fine. Is this TV HDCP compatible? Is the HDMI port compliant with current specs? Where can I go to find out if these two items are compatible. How can resolve this issue?
I have tried 2 DMR's, , 2 different HMDI cables. The first cable has gold connectors , 19 pin , latest technology. The second cable had a bandwidth of 5 gig. I could not find a cable labeled ver. 1.1.
I have connected the DMR and HDMI cable to another flat panel TV with no problems. I have contacted Akia tech support not getting anywhere. They have stated that the HDMI port would only work with ver, 1.1 or 1.2 cable. I purchased the low bandwidth cable with no success. Akai now says that the HDMI port will accept the signal because it is coming from an HDCP device.
Help Help Help !
Thanks!
My Mac mini works via the HDMI port.
Return set!
Akai Tv is not HDCP compatible. Nothing worked akai was not very helpful. This model , a 2006. aparently will not communicate will the newer HDMI devices.
RETURN SET IF POSSIBLE. NO SOLUTION FOR THIS PROBLEM!
This is a good one i had the same problem about a year a go on my brothers we tried every thing nout worked i said put the video leads in and do it it worked a treat but i have herd it don't work for all so it sounds like an amplifier my be needed hope any of this can help you. sorry if it don't only trying to help
SOURCE: HDMi ( no signal, not supported) doesn't work with Dmr
I have lost my manual for the lct27ta. Have you gone into the menu and setup the hdmi port?
SOURCE: HDMi ( no signal, not supported) doesn't work with Dmr-Ez47v
Any HDMI cable manufactured in the last couple of years should all be HDMI 1.1 compliant, your problem is most likely the logic board in the TV itself or the HDMI connector on the logic board has a bad connection..
Have you tried hooking-up a standard DB15 VGA cable to the AKAI TV and your laptop?
If this works your problem is in the TV and will most likely have to be repaired to receive the HDMI signal since your Panasonic DVR and your laptop are not recognized by the HDMI input on the TV.
Ren
I am having a very similar problem as I can not connect the Xbox 360 through HDMI and this is upsetting me- has anyone found a solution? I know that this tv (mine is the 32") has the ability to upgrade firmware so I was wondering if that could be a fix? I still have 2 years on an extended warranty i purchased with the TV but don't care for the down time! PLEASE HELP!
The HDMI ports don't recognise anything, ive tried various hmdi cables and they aren't the issue, its something to do with the tv
