Cars & Trucks Logo
A
Anonymous Posted on Nov 30, 2013
How to remove door locks
Door locks not working
mikadot
Level 3:
  • Master 2,113 Answers
  • Posted on Nov 30, 2013
mikadot
Master
Level 3:
Answers
2113
Questions
0
Helped
465769
Points
5959
Pull off the inside of the door by removing the armrest bolts. Pull any electrics if they are in the way or any window cranks. Pull the panel off. Undo wire harnesses. reach inside where the handle is and find a sheet metal clip pull it sideways with a pair of pliers. undo the metal rod clips by turning a nylon fastener to the side and unsnapping the rod. put in the new tumbler and slide the sheet metal clip in again. snap on the rod and twist the nylon clip back. put the panel and armrest back on. repeat for other door.
1helpful
I need to remove this lockwood lock from my front door as it has stopped working but can't work out how to remove it
if its still locked and not working , then your in for a real chore !! as these are designed to not be able to just unscrew if there locked up , if its not locked , open door and unscrew frame part from frame (screws held it on frame) then look at bottom of key lock section , see small set screw (use allen key on this ) remove this screw , then using a small pipe wrench (you didn't want to keep it right ?) unscrew the lock section lefty loosey and then with a slight pry with small screwdriver entire front cover will pop off , this exposes the screws into the door , remove them an lock will come off door (leaves big holes in door thought)
Central locking button not functional and I can't lock the rear door glass
if its just 1 door that wont lock, I would say that the lock mechanism on that door has failed. When you press the central locking , you should hear each door "click" if its only 1 door, remove the door panel to check if any wiring has broken or dislodged. To check the door lock unit, I found it easier to remove it and check with a unit from one the doors that you know does work. If the good one you swapped over works, then that will mean that the lock unit has failed, if the good one doesn't work on that door, then you know it will be a wiring or connection fault to that door.
2answers
Opening locked door
You will have to remove the door panel and test the latch. Since the switch has power and is working, the problem is either the wiring to the latch or the latch itself. Since it is not working manually, the latch is most likely the problem.
1helpful
L door dose not lock all door locks
This may be due to a bad lock actuator, i will need to ask a few questions first.Can you lock the door by hand using the button? or is the lever stuck?Is the problem that it does not work with the power locks only?
Let me try to answer these, first if the door lock does not work with the power locks then the door lock actuator may be bad, the door panel will need to be removed and test for power at actuator. While inside the door check lock linkage.If the door lock lever wont move then that may also be related to a frozen lock actuator, that is the same as above. a bad or frozen lock actuator will not allow door to lock or unlock but sometimes a bad actuator will not work with the power button but will allow you to lock and unlock with lock lever or door key, the door panel needs to be removed to check . good day.
1helpful
How do you remove the door handle from the subaru forester
For Doors not getting open with remote or key problem, there are help links provided below. Click the link below to go through its procedure and troubleshoot the problem: ----
Drivers side front door will not open from inside or outside?
http://technoanswers.blogspot.com/2012/01/ford-f-350-crew-cab-drivers-side-front.html
Car door will not close?
http://howtobyme.blogspot.com/2011/11/car-door-will-not-close.html
All power door locks not working?
http://howtobyme.blogspot.com/2011/11/all-power-door-locks-not-working-on_14.html
Repairing car Door lock Actuator?
http://howtobyme.blogspot.com/2011/11/repairing-car-door-lock-actuator.html
How to Access car door panel?
http://howtobyme.blogspot.com/2011/11/how-to-access-car-door-panel.html
Vehicle door panel components?
http://howtobyme.blogspot.com/2011/11/vehicle-door-panel-components.html
Truck Door will not close?
http://schematicsdiagram.blogspot.com/2011/12/ford-truck-door-will-not-close.html
Where is Cars Door control Module located?
http://schematicsdiagram.blogspot.com/2011/12/where-is-cars-door-control-module.html
Power door locks not working?
http://schematicsdiagram.blogspot.com/2011/12/power-door-locks-not-working.html
Door ajar light stays on?
http://technoanswers.blogspot.com/2012/01/door-ajar-light-stays-on.html
Door locks not working?
http://technoanswers.blogspot.com/2012/01/door-locks-not-working-on-ford-explorer.html
Front Door dis-assembly diagram?
http://repairhelpcenter.blogspot.in/2012/02/front-door-dis-assembly-diagram-for.html
Rear Door dis-assembly diagram?
http://repairhelpcenter.blogspot.in/2012/02/rear-door-dis-assembly-diagram-for.html
How to test Power door locks?
http://repairhelpcenter.blogspot.in/2012/02/how-to-test-power-door-locks.html
Doors will not open with Remote?
http://schematicsdiagram.blogspot.in/2012/02/lexus-doors-will-not-open-with-remote.html
How to replace Door Hatch ?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-hatch-on-acura-integra.html
How to remove Doors?
http://repairhelpcenter.blogspot.com/2011/11/how-to-remove-doors-on-acura-integra.html
How to Replace Doors?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-doors-on-audi-a4-and-vw.html
Remote will not unlock Rear door?
http://schematicsdiagram.blogspot.com/2011/12/remote-will-not-unlock-rear-door-on-gmc.html
Door locks or windows not working on car?
http://schematicsdiagram.blogspot.com/2011/07/door-locks-or-windows-not-working-on.html
Central locking not working?
http://schematicsdiagram.blogspot.in/2012/03/this-is-how-system-operates.html
This will help.
Thanks.
How do i remove and replace drivers side door window
For Doors not getting open with remote or key problem,there are help links provided below.Click the link below to go through its procedure and troubleshoot the problem:----
drivers side front door will not open from inside or outside?
All power door locks not working ?
This will help.
Thanks.
1999 a6 avant passenger side door panel removal
For all types of power window problem and power windows not working,i suggest you to go through the help links given below. Click the link to go through its procedure to troubleshoot the problem :------
Power window problem
http://repairhelpcenter.blogspot.com/2012/01/pontiac-grand-am-power-window-not.html
Power windows not working after car wash?http://howtobyme.blogspot.com/2011/11/power-windows-not-working-after-car.html
power locks, power window and power mirror not working?
http://howtobyme.blogspot.com/2011/09/power-locks-power-window-and-power.html
All power windows not working?
http://howtobyme.blogspot.com/2011/09/all-power-windows-not-working-on-2003.html
How to remove window motor and regulator on Car?
http://howtobyme.blogspot.com/2011/09/how-to-remove-window-motor-and.html
Complete Diagnosis & Testing Power Windows?
http://repairhelpcenter.blogspot.in/2012/02/diagnosis-testing-power-windows.html
-----------This will help.Thanks.
2011 volvo s60 door removal
This will help.
Thanks.
1helpful
2004 volkswagen passat inner door panel removal
This will help.
Thanks.
'87 Camry door lock doesn't work
Try putting a little graphite lock lube in the lock to see if it is just stuck first. Does your key work on the other locks? Do you have a spare key that you haven't tried? If you need to pull the lock, use a trim removal tool to pull the door panel off, starting at the bottom removing the clips on the outer edge of the panel. Unscrew the fasteners holding the armrest on and be careful of the door handle to avoid bending the linkages. Door locks don't fail too often.
Top Ford Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Ford Expert? Answer questions, earn points and help others
