Says press steam and nothing happens
SOURCE: refilling system
same problem.. "fill system press steam" but no water was flowing. The pump has an air bubble in it. capressa customer service advised to continue (up to an hour of retrying if necessary) pressing the steam button, let the machine rest for a few minutes and retry again and again until the water starts flowing. Sure enough, after 45 minutes, and 30 or so times of pressing the button, it started to work again. While I was wasting away my saturday morning with this, Williams Sonoma said that they would have the machine repaired at no charge and have it shipped back to me if I wasn't able to get it working. I've owned this machine for almost 5 years (bought in Jan '05) and this is the only time I have had a problem. ..and to be fair, I had let the machine sit for several weeks without use, or water in the tank, when I encountered this problem.
SOURCE: Jura S9 Capresso Machine "Fill System" Message
I think you use too fine grist on the grinder, or the coffeebeans are really dark and moisty. Try to set the grinder to a coarser grist, for dark roasted coffee it`s not recomended to to use any finer than medium grist. However, the sieve in the brewing unit could be clogged, and you need to clean this out. Put a finger up in the brew unit just along the grounds blade, you will probably find a lot of old fine coffeeground up the. Clean it up as best as possible, and then try to make coffee with coarser grist. If this helps, it`s smart to run a cleaning program to be on the safe side.
If nothing of this helps, you don`t have a choice, you have to send it for service, then the brew unit has to be dissasembled and cleaned from the inside.
SOURCE: my jura capresso says system fill...it makes a lot of noise
System fill is usually when the machine auto solenoid fill valve is putting water into the boiler. If it is making noise then the solenoid is clogged or there is no water getting to the solenoid.
SOURCE: Jura Capresso Impressa S9- no steam
I had a similar problem. I took off the side and rear cover, followed the hose that comes from the steam wand to the rear of hte unit. It enters a solenoid made by ACL Italy. I dismantled the solenoid unit by disconnecting the two hose ends, removing the relay, and unscrewing the plunger unit (vertical pipe). The plunger unit internals should move freely up and down like a piston in a cylinder , powered by a small spring. In my unit, this plunger was calcified and seized. I soaked it in boiling water and pressed on it gently several times and it unstuck. I put it all back together again and presto! Good luck
