It will probably be easier to wire the sound bar to the "Audio Out"" on the TV, the DVD player to the HDMI on the TV then change the settings in the TV.
On the back of most TV's there are 'Phono Jack' connectors and newer TV's have a 'Digital Out' that uses an Optical cable to transfer the sound. Use one of these to connect the sound bar and usually anything you play through the TV will play through the sound bar.
Depending on your TV, the settings to switch to the sound bar will be in the Sound or Audio section.
the details you provided were very vague, however from my experience when a device is connected to another device via and audio capable hdmi cable, that device renders it audio output to the device its connected to and normally turn off all other audio outputs beside optical- I would assume there is an option in the blue ray player to turn off hdmi audio, which will in turn activate other audio outputs- you may also look for audio out port on your tv, it is ideal to connect the sound bar directly to the tv set audio out ports. To sum this up, if you plan to use your player via hdmi cable you need to turn off hdmi audio output on the blue ray player and the plug an audio cable from your blue-ray player to your sound bar you may also as i said connect your sound bar directly to your tv, the issue is most tv sets now a days do not have an audio out port, if you do then everything you play thru your tv will have audio via sound bar there are several way to go here but unless your sound bar has hdmi av switching capabilities (im sure not) this is one of the most simple--Good Luck.
You have obviously connected the sound bar's RCA (red, and white) cables to the TV's IN jacks rather than the OUT jacks, OR you might have them connected to the RCA VIDEO jacks. Check it. Connect them to the TV's audio OUT jacks. Presumably, the inputs on the back of the TV are marked "audio out", and the IN connections from your sound bar must go into the OUT inputs on your TV. I can't imagine what else it could be causing the problem.
its old model, will not pass hd video, good only for audio. Connections depend on your equipment. If you use a cable box to watch tv, connect cable box audio out rca connectors (red and white), by an audio rca cable, to audio TV input on the back of the receiver. Now when you swith your receiver to TV input you get sound from cable box trough your speakers.
If you use DVD player: connect audio out of the player to dvd audio input of the receiver. Switch the receiver to DVD input, you have sound from DVD.
hi, did u mean connecting the sound bar to ur tv. u didn't mentioned the model number of ur sound bar. any how ur tv has only coaxial digital audio out. no analog audio out. the sound bar may have one digital audio input (optical digital input) and 2 analog inputs. if it has coaxial input it may be very easy.find is there, if not u cant link these devices. if u are using a satellitereceiver then u can connect the optical audio out to ur sound bar's optical input or the analog audio output to any one of the analog audio input. ok
Hello, i just saw your post.. i know this reply is so late, and you might have probably found a solution. But i will still give you some guides to help you figure this out.
(1) First and foremost, make sure your connections are set up properly (exactly as in the manual). most HDTV'S require a DIGITAL OPTICAL CABLE to be connected from TV to receiver. Read the manual on your TV and see the required wires for external audio
(2) go to your TV audio settings. Get to the speaker option, and turn it off ( this assumes your expensive TV is an HDTV). By turning it off, you signify that you want the sound option to come only from the speakers.
