Hello,my I-pod is disabled and I don't know the password. how can I unlock it??!
If your iPod is disabled from a passcode that is entered too many times you'll want to follow:
http://support.apple.com/en-us/HT1212
It will instruct your to put your iPhone into recovery mode to do a restore to factory setting (this will erase the iPhone).
If you have a backup available, that doesn't have the passcode in it then use:
http://support.apple.com/en-us/HT203977
Be warned that if the passcode is on the backup and you do not know the code, then you will be back to square one and have to restore it to factory settings again. Good luck!
You have to call apple
SOURCE: I forgot my I touch 8 g four diget password and
Apple say if you connect your ipod to itunes a pop-up should appear saying do you want to change your pin
SOURCE: unlock code from ipod
It depends on the severity and the settings you have given the iPod... Here's the full explanation. I would recommend reading the second paragraph first, but the solution if you really forgot your password is in the first paragraph.
If you cannot remember the passcode, you will need to restore your device on the computer that was used to originally sync the iPhone or iPod touch so that you can reset your passcode and resync the data from the device (or restore from a backup). If you restore on a different computer that was never synced to the iPhone or iPod touch, you will be able to unlock the device for use and remove the passcode but your data will not be present. Refer to "Updating and restoring iPhone and iPod touch software."
"If you enter the wrong passcode too many times, you'll see a message that says "iPhone is disabled" and to try again later. If you repeatedly enter the wrong passcode, iPhone or iPod touch will be disabled for longer intervals, before you can try again. After too many unsuccessful attempts, you won't be able to try again until you connect to the computer you normally sync with. Note that starting with iPhone 2.1 software, there is a setting to cause the device to erase itself after 10 consecutive incorrect password attempts. This setting is off by default. It can be turned on by tapping Settings > General > Passcode Lock after you enter a correct passcode."
The full article can be found here: http://support.apple.com/kb/HT1212
SOURCE: I pod is disable , unable to unlock using password
Warning: you will lose all your data
