I'm convinced you already did read the user manual. There are three things you can reset:
1. User settings. In menu mode P, you can undo all the settings you made. Page 69.
2. Reset all settings. Page 151 Menu settings, chose the wrench symbol and chose reset all. All settings will be restored to factory settings.
3. Reset file numbering. Page 154 Menu settings, chose the wrench symbol and chose reset file numbering.
In the same menu is also the view firmware version. Yours should read Coolpix P90 Ver.X.X .
The latest update of firmware for the P90 is 1.1 Great chance your camera came with that revision already. If you registered your camera with Nikon, they will inform you when a new firmware is released.
Really, there is nothing more you can reset on the camera.
So if something is wrong, it can't be helped with the reset you have in mind, because that reset does not exist.
If you want the firmware 1.1, goto Nikon USA and support. Everything you want is there.
I don't hunk there is anything like reset your camera. Nikon allows you to set back settings, each to a certain level, but that has nothing to do with a compete reset, like you would do on a computer or phone.
If your camera should be "reset" Nikon would not only say reset the camera, but also should explain how to do that in the instruction for how to put in a new update.
Try this,
1. Check your Windows Device Manager and see if all hardware is recognized and installed properly.
2. It might be that the hardware is recognized as a camera, but the right drivers are not
installed. The yellow explanation mark will indicate a problem.
3. In that case you can try to update the drivers. Right-click the device, and in the
popup menu select Update Driver Software. Then follow the instructions on screen, but
make sure you allow Windows to search the web for updated drivers.
If this works and helpful, please give a testimonial and vote by pressing button four thumbs up icon.
Sincerely,
Thiyaga
Please reset the router by using pressing the reset button for 10 seconds. Default username : admin, default password : admin
If it does not connect, update the driver by visiting the linksys site.
Webmaster www.incomeinnet.com (An online encycopedia on earning money through internet legally)
First you have to restart the phone and the reset it.Beacause the apple ios is corrupted you have reset the ios to work properly.When you reset the apple i phone new Ios will be re-installed it will not update it will only reinstall so the firmware will work properly.
To restart iPhone running iOS 3.0 or later
1. Press and hold the Sleep/Wake button until the red slider appears. When the red slider appears, release the Sleep/Wake button. 2. Instead of dragging the red slider, press and hold the Home button for six seconds. 3. If the device does not return to the Home screen, see the steps below to restart.
To restart iPhone iOS 2.2.1 or earlier
1. Press and hold the Home button for six seconds. 2. If the device does not return to the Home screen, see the steps below to restart.
If the iPhone touch remains unresponsive, try restarting the device:
Restarting iPhone :
1. To turn it off, press and hold the Sleep/Wake button until the red slider appears. 2. Slide your finger across the slider to turn off iPhone. 3. To turn iPhone touch on, press and hold the Sleep/Wake button until the Apple logo appears.
Resetting the iPhone:
Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds.
If still the problem persist you have to update the firmware:
Updating and Restoring iPhone Software
You can use iTunes to update or restore iPhone software. You should always update iPhone to use the latest software. You can also restore the software, which returns iPhone to its original state.
If you restore, all data is erased from iPhone, including songs, videos, contacts, photos, calendar information, and any other data. All iPhone settings are restored to their original state.
1. Make sure you have an Internet connection and have installed the latest version of iTunes from www.apple.com/itunes. 2. Connect iPhone to your computer. 3. In iTunes, select iPhone in the Source pane and click the Summary tab. 4. Click “Check for Update.” iTunes tells you if there’s a newer version of the iPhone software available. 5. Click Update to install the latest version of the software. Or click Restore to restore iPhone to its original settings and erase all data on iPhone. Follow the onscreen instructions to complete the restore process.
post a comment for further assistance. Thank you for using fixya have a nice day:-)
hi try to reset ur camera...To do such reset, turn on the camera and hold the menu button down for longer than 5 seconds. A message should hopefully come up on your LCD asking if you want to reset the camera. Select Yes... thank u!!! rate me!!
Normal
0
false
false
false
MicrosoftInternetExplorer4
st1\:*{behavior:url(#ieooui) }
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
Normal
0
false
false
false
font-size:10.0pt;
The latest software which can be
done by installing a program called WebUpdater. WebUpdater can be installed via
the link below and you must use it:
Once updated please allow the unit to reboot which will ensure the software
successfully installs.
After installing WebUpdater oncefrom the Garmin website, perform all future
software updates from your computer. Simply connect your compatible Garmin
device to your computer, then run WebUpdater from your computer's "Start
Menu" by selecting "Start", "Programs",
"Garmin", and finally "WebUpdater" Garmin
Communicator Communicator Plugin is properly installed and up to date, version
2.9.1.0.(Dec 21, 2009)
If after following all the above the final steps would be to perform a master
reset.
Start with the unit OFF and unplugged from power
Touch and hold the lower right corner of the screen with an index
finger or the eraser end of a pencil
Continue touching and holding the lower right hand corner of the
screen then power the unit ON
Release the power button when the device powers on. After 5-10
seconds you will see a new message: Do you really want to erase all
user data?
Remove your finger from the touchscreen when this message displays
Touch Yes, and wait
The device will automatically reset. Please follow the on screen prompts on the
nuvi and when completed place your device in an area with a clear view
of the sky until it acquires satellites.
Full_flashplayer_win_msi - http://www.macromedia.com/go/full_flashplayer_win_msi or install_flash_player_10_active_x.msi
********* Problem persists? YES!
start / Control Panel / Internet Options / delete / delete everything and mark the "Delete Files and Settings also
stored for supplements. "
Click the Settings button in the "history of navigation" / button "View objects" / remove all objects that are as
uninstalled or damaged. After removing the objects click "OK."
Click the tab "Advanced" option and click on "Restore advanced settings," then the button "reset" and again
the "Reset" button.
Still tab / tab "Advanced", uncheck the option "Enable third party browser extensions."
Tab "Privacy", click the "advanced" and check "Override automatic cookie handling" and also mark
"Always allow session cookies", click "OK"
Tab "Security", click "Custom Level" and then click the "reset" and "OK."
Navigate to the folder C: \ Windows \ System32 \ Macromed and Rename the folder to Macromed.old
Clicking Start / Run / type Regedit Go to the key: HKEY_LOCAL_MACHINE \ Software \ Macromed - Rename the key to Macromed.old
Go to the key: HKEY_CURRENT_USER \ Software \ Macromed - Rename the key to Macromed.old
Restart the computer.
**** VERY IMPORTANT ****
After restarting the computer, install the Flash Player by downloading done in the beginning "Full_flashplayer_win_msi"
Soon after installed, go to youtube or any site of preference and see if the flash worked.
If you have 2 browsers such as Firefox, you need to install flash for firefox. Sign http://get.adobe.com/br/flashplayer/ through Firefox and install the Flash again.
the "Reset" button.
Still tab "Advanced", uncheck the option "Enable third party browser extensions."
Navigate to the folder C: \ Windows \ SysWOW64 \ Macromed and Rename the folder to Macromed.old
Clicking Start / Run / type Regedit Go to the key: HKEY_LOCAL_MACHINE \ Software \ Wow6432Node \ Macromed - Rename to Macromed.old
