SOURCE: door wont lock
I solved my own problem...
The machine stopped due to either a heavy load or clogged drain. I cleaned the drain (by taking pannel off the front of the machine). Then, the machine wouldn't cycle and it said "door locked" but the door wasn't locked. Basically, you have to let the machine finish a complete cycle (whether or not it actually does anything). Every time the start/pause button flashes, push it to have the machine try to start. This will eat away at the time. Eventually it will finish the cycle and say 0:00. Now it should run. This can take up to 2 hours so be patient!
SOURCE: Water in tub and nothing happen when we try to wash cloths
usually this is indicitive of a bad pump or something stuck in it.these machines when first started they try to pump out first
the cycle will continue as long as it senses water
have them inspect the pump
good luck with sear service i hope it goes well
SOURCE: ice maker and water dispenser front panel lost power
My door dispenser loses power and I can uplug fridge and plug back in and I have power, then after a few minutes the power goes off again.
SOURCE: OWN GE front load washer model
Hi--I've got the same model, but it's behaving like there's an unbalanced load, shimmying all around the floor, & damaging the wall behind...do you know if there is a selection for different sized loads, ie a small load...can't see that wording on the panel; did you get your problem sorted? The manual is not much help, is it...thanks. Maria.
