Electrical Supplies Logo
c
craig shisler Posted on Nov 29, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Generac 15000 watt generator blows 15 amp fuse when it try to exercise
When generator exercise it blows the 15amp fuse before it starts not every time maybe third or fourth time if power gos out generator tramsfers ok and works
mike kirschbaum
Level 3:
Genius:
  • Master 1,198 Answers
  • Posted on Nov 30, 2013
mike kirschbaum
Master
Level 3:
Genius:
Answers
1198
Questions
Helped
359168
Points
3184
What does the fuse power?
Generac ultra source 15000 watt generator runs for about 12hours then shuts off after a few hours it will start back up and do the same thing
Could be the fuel tank is not venting properly. When it fails, remove fuel cap and try starting. If it runs replace fuel cap wuth new.
When I start my 15000 watt generac generator I have to excite the field to get voltage? It is a ultra source guardian when I first start it. The rpm is erratic until I get voltage.?
That may be normal. Some generators have to have the magnetic field excited in order to increase the magnetic lines of force for the armature to cut through.
When i start the generac 15000 it starts fine but once a load is put on it it will die aS SOON AS THE LOAD STARTS IT JUST QUITS
Check the governor and throttle for easy movement. When the load increases, the governor should advance the throttle to keep the speed up.
How do i remove the camshaft from generac 15 k generator
I would do a compression test before you removed a cam.
How did you diagnose the camshaft?
Cranks then dies
yes this unit will run for only a second or two then dies. the fuel pump is pumping well
3helpful
I need a wiring diagram for a generac gp15000e generator
I have a 15000 ultrasource generator the start and stop switch was taken out i need to put it back The problem is i dont know which wire goes where and when i look at the wire diagram the numbers are different the numbers on my unit are 15, 11, 133, 14, 12, The 15 and 11 are the same wires the start and stop switch has 6 males on the back to plug the wires into Does anyone know which wire goes where???
1helpful
2answers
Dont have 12 volts to start switch generac guardian ultra source
Have you checked the fuse? Mine keeps blowing the fuse (located on the back of the control panel) with each startup and shutdown or use of idle control.
13helpful
2answers
Generac Guardian 15 kw overspeed fault
Did you remember to set the overspeed shutdown threshold on the control board?
Top Generac Electrical Supplies Experts
vince
Paul Bade
Are you a Generac Electrical Supply Expert? Answer questions, earn points and help others
