When we run the dishwasher, the soap packet is not being released. I open the door at the end of the cycle and a mangled packet falls. I have tried the normal cycle, the smart cycle and the quick cycle....replacing soap each time. Same thing every time! Appliance is 1 month old.
SOURCE: Soap door is open when cycle is over but soap does
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenanceDishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
SOURCE: My DMR78AHS dishwasher stopped washing. It runs
I had the same problem. My solution was to remove the bottom portion of the inside of dishwasher to reveal the cutting blade under the washer impeller. There was a small obstruction blocking the cutting blade and impeller. I removed this, a small piece of plastic im my case, and re-assembled. It washes well now ! Note: be careful seperating the parts there are 'o' rings that can be easily stretched out fo shape between parts.
