Motorola Mobility W385 Cellular Phone Logo
A
Anonymous Posted on Nov 29, 2013
Turn off airplane mode - Motorola Mobility W385 Cellular Phone
I have a Samsung Galaxy J3..I was wondering if there is a way to remove the "turn on airplane mode" verification, so to turn on my airplane mode, all I'd have to do is click on the Airplane mode icon..
No because it is too dangerous. When you go into Airplane Mode, you literally turn everything off! Airplane Mode is only for being on an airplane. If you are using it a lot whilst not flying, you are not using it correctly.
4answers
On what make and model?
Sep 06, 2017 • Cell Phones
1helpful
Irola tablet stuck in airplane mode.can't turn off airplane mode
You have to do a hard reset its not seing your sim card ask me how if you don't know how
Jan 29, 2016 • Cell Phones
2answers
After installing Windows 10, why won't airplane mode turn off and wifi is limited?
How to turn on or off Airplane Mode in Windows 10
Option 1:
1. Open Action Center (Windows Key + A)
2. Click/tap on the Airplane mode quick action button to toggle on or off.
Option 2:
1. Click/tap on the network icon in the taskbar notification area.
2. Click/tap on the Airplane mode button to toggle on or off.
Option 3:
1. Open Settings, and click/tap on the Network & Internet icon.
2. Click/tap on Airplane mode on the left side, and turn on or off Airplane mode on the right side.
3. When finished, you can close Settings if you like.
Airplane mode issues can be of different ways. One might be unable to turn off the airplane mode as its toggle indicates the function is unavailable for the time being. Few users might not be able to activate the wireless connections as they are not willingly glued to the Airplane mode. And there are situations where Airplane Mode turns on automatically refusing other wireless devices to perform correctly. So, we provide you different solutions to try for the above mentioned Airplane Mode issues. So, let us head towards the main topic and see How to Fix Airplane Mode Issues in Windows 10.
How to Fix Airplane mode not turning off in Windows 10:
Solution 1: Change Network Adapter Properties
1. search for Device Manager in Start Menu or Cortana and open it.
2. Make your way to the Network Adapter section and expand it by double-clicking on it.
airplane-mode-turn-off-after-installing-qxiko4mbhn3xwpbyjhiay14v-2-0.png 3. Figure out your wireless modem from the available list and right click on it to navigate to its Properties.
airplane-mode-turn-off-after-installing-qxiko4mbhn3xwpbyjhiay14v-2-2.png 4. This launches the Properties dialog box of your adapter. Hit on the Power Management tab. Clear off the option that saysAllow the computer to turn off this device to save power.
airplane-mode-turn-off-after-installing-qxiko4mbhn3xwpbyjhiay14v-2-5.png 5. To apply the changes, press Ok button. This will Fix Airplane mode not turning off issue in Windows 10 and resume its slider to be turned off.
Check the other solutions here Airplane mode not turning off in windows 10 Fixed
Airplane mode
I presume you have a Windows 8 operating system.
1. Press [Windows Key] + Q key.
2. Type "airplane" in the Search box,
3. Click the "Settings" (it is found in here)
4. The "Turn Airplane mode on or off" note will be displayed; click it.
5. PC Settings screen with airplane mode slider will be displayed,
6. Slide the Airplane mode slider to off.
Remove flight mode
Turn on / off Airplane mode
Airplane mode turns off the wireless radio. This allows you to use programs while travelling on an airplane, but not make or receive calls.
To turn on airplane mode, follow these steps:
  1. From the Home screen, select Go to.
  2. Scroll to and select Profiles.
  3. Scroll to and select Flight.
  4. Select Activate.
To turn off airplane mode, follow these steps:
  3. Scroll to and select Normal (or a profile other than Flight.)
  4. Select Activate.
2helpful
3answers
I have droid phone. Says on airplane mode. How do I turn airplane mode off?
1. Press and Hold the Power button for 2 Seconds. A menu pops up. On that list, you will see "Airplane Mode" (under which should state "Airplane mode is ON").
2. Now tap "Airplane Mode" to switch it Off. If you press the power button again after a few seconds, it should now say "Airplane Mode is OFF". This is how you want to leave it. Done.
9helpful
3answers
What is airplane mode and how do i get out of it??
Airplane Mode (Motorola CLIQâ„¢ with MOTOBLURâ„¢)
NOTE: Airplane mode turns off the wireless radio. This allows you to use programs while travelling on an airplane, but not make or receive calls. An Airplane icon appears on top of the signal bar when airplane mode is active.
To turn Airplane mode on or off, refer to the following:
Using the Lock key
To use the Lock key to turn off Airplane mode, perform the following steps:
1. At the Home screen, press and hold the Power/Lock key on the right side of your phone.
2. At Airplane mode, tap On or Off.
Using the Settings menu
To turn the Airplane mode on or off using the Settings menu, perform the following steps:
1. At the Home screen, press the Menu key.
2. Tap Settings.
3. Tap Wireless controls.
4. Tap Airplane mode to turn on or off.
Top Motorola Mobility Cell Phones Experts
AFIFUL HAQUE MUFTI...
Level 1 Expert
vince
john h
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
