Dryer heated up way hot had to shut down. now wont heat at all.
SOURCE: dryer still wont heat
you could remove and bench test the theromostat. my kenmore would not complete the circut to heat at all with a faulty thermostat. Just use a jumper wire to bypass it and test it THERE WILL BE NO SHUT OFF COULD HEAT UP TOO MUCH IF LEFT RUNNING.
SOURCE: whirlpool imperial series 6 cycle/3 temp electric dryer wont heat
My dryer is not heating, where is the cupling at in the dryer i have it open tho
SOURCE: Whirlpool LEN100PQO electric dryer wont shut off/no heat
if your thermal fuse is blown you will not recieve heat. if you put your dryer on sense load it will keep running because it is not sensing that the clothes are getting dry which in return your timer does not
advance
SOURCE: no heat , drum turns and wont shut off
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
SOURCE: Dryer heats up buts keeps shutting off?
It could be the blower air velocity if not then you have a bad winding in the motor.Motor gets hot and shuts off and then comes back on
after it cools. Also it could very well be the vent crushed by the dryer.
Questions go here
Leo Ponder
[email protected]
