I have found that the switch activated by the door close or turns on the interior light when open on is likely the problem. You may notice that if the door is open and you push on the start button, it will buzz. So if the door is closed and you get this buzz when pushing the start button, there is a problem with the door switch. The start button "thinks" the door is open, and therefore not start. The defective door switch needs to be replaced. At least highly likely.
The buzzing is probably the relay trying to start the motor. See if the motor has a capacitor, have it checked. If the motor is all clogged with lint, the start/run switch can get blocked. Clean out all that lint with a vacuum cleaner.
Check the tub bearing, and make sure the drum spins freely.
SOURCE: whirlpool lgr4634eqo makes a buzzing noise when trying to start
Try holding the door switch lever in and turning the drum hard by hand. It sounds like you have a start switch out in the motor.
SOURCE: Whirlpool Dryer (LER7646E) not working
check your power cord and the receptcal if you see any discloring on pronges of your power cord you'll need to replace cord and the receptical it could be shorting out
SOURCE: whirlpool dryer makes a buzz noise when push
pull motor switch out(the one with wires go in motor) best use compressed air.... lint is stopping lever... this all happens after you turn breakers off...hi hi
SOURCE: Whirlpool LER 5436 tumble drier- loud buzz
When start button is pushed there is a buzzing noise but dryer will not start.
SOURCE: Whirlpool gas dryer heats sometimes. sometimes it
sounds like you have a connector that is loose.unplug dryer and check all wire connectors.
