I was using the self cleaning mode and it cleaned the oven but then after the cycle finished the code E1 F5 appeared and beeped. We turned off the breaker for 30 min. but it did not reset itself. I hit the cancel button, but it still is displaying E1 F5 and the door will not open. Please can you help
SOURCE: The F5 error code?
WHIRLPOOL
Range/Stove Oven Fault Codes, Common
Failure
Code
Condition
Check/Repair
Digit Failure Code2
F1
Analog to Digital Failure
Disconnect for 30 seconds - if display reappears - replace control board
F1
Safety flip flop
Replace board
F1
Shorted keypad
Replace keypad
F3
Oven temperature sensor opened
Replace oven temperature sensor
F2
Oven temperature sensor shorted
F3
Oven too hot
F3
Clean temp too hot
F5
Check door/latch switch
Replace switch if defective
SOURCE: We tried using the self clean on our Whirlpool
take the trim peices off. take the screws that hold it to the wall out slidee unit out a little to remove the 2 screws from the consol lift the consol up and off. make sure that you have turned the power off inside the unit you will see a tech sheet that will tell you what that error code means. let me know how it goes the tech sheet is usually on the left side.
SOURCE: When I try to start the self-cleaning oven,
there are switches under the cooktop that go bad frequently. i do not recommend ever using the self clean mode in an oven. the oven gets so hot that things have a tendency to melt because they dont build stuff like they used to. there is inadequate insulation in modern ovens. use easy off and follow the label directions. it'll be cheaper in the long run, trust me.
Testimonial: "What you have suggested makes sense to me. Thank you!"
SOURCE: e1 f5 error code whirlpool gr399lxhs
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.(*&^$%^
SOURCE: Have Whirlpool Electric Range super capacity 465
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.$%^TF
Make sure that the oven door is closed when you start the Self Clean cycle. Check the door switch to see if it is apparently operating properly. Open the oven door and the oven light should turn on. Press in the door switch plunger and the light should turn off. If the light switch is not operating properly, it could cause this type of problem.
If the light switch is operating properly, then you could have a failed door latch assembly. A wiring failure or a problem with the control board could also cause this failure. I recommend that you unplug the range and access the door latch assembly at the back of the range. Pull the upper and lower back panels off of the range. Caution: The edges on these panels can be sharp. Protective gloves are recommended. With the panels off, check the wire harness connections on the door latch assembly.
