Motorola Mobility L301  Cordless Phone Logo
D
Derick Panchoo Posted on Nov 29, 2013
Message:warning check battery . I have just replace the battery
It is not taking charge . The battery have been replace only a month now.
Yasaheb
Level 1:
New Friend:
  • Contributor 18 Answers
  • Posted on Dec 04, 2013
Yasaheb
Contributor
Level 1:
New Friend:
Answers
18
Questions
6
Helped
1235
Points
47
Dont mention it please change with the essential battery
Why do i get a increased battery discharge message on bmw 2012
1. If you have a sound battery (and you may not) most likely the alternator is providing insufficient charge to the electrical system in the vehicle when driving and the demands of the system are drawing power from the battery.
2. The battery itself may also be weak and need to be replaced. A weak battery will frequently generate system warnings of various kinds. If it is the original battery still in the 2012 car then as a first step replace the battery with a new one as they can easily begin to fail at 3 years.
The electrical systems on these cars are extremely complex and if you still get the warning message after the battery is replaced then take it to BMW service and have them check the car over. Yes I know that is expensive but that goes with buying that particular brand of car. When you have problems in future with these cars, and you will, they will inevitably be quite expensive to fix in many cases and require specialist knowledge.
NEW BATTERY IS FLAT
Check your charging system. Most of the battery life gurantee is months. so you may need to replace the battery
No Battery Warning - Turning off at 20%
May be time to replace the battery.. or charging problem i advise you to take it to the service center.
Vibrating when charging every 5 seconds. Message says battery disconnected?
Clean connections at battery source. Check adapter and plug of adapter for power and clean terminal of adapter and where it plugs into unit also.
1996 balzer battery dead after 2 months of sporatic use followed by another montth of total inactivity ... could this be caused by bad alternator?
could be but you should get a warning say the alt not charging. check for a draw on the batt like vanity lites staying on ect. you can take it to autozone or any parts place they will check your charging system for free
2answers
May battery light always on
This may indicate a problem with the battery or in the charging system. Take the car to an autoparts store and have them check the battery and alternator output. Most parts stores offer this service at no charge. Hope this helped and best wishes.
1helpful
Charging system
it could still be the alternator it may have warn brushes or bad reg
2answers
Battery low
This may seem like a dumb question, but have you tested the lighter socket to see if it's working? If the TomTom is plugged in, you shouldn't get a low battery warning.
Top Motorola Mobility Lands Phones Experts
Ngoro
john h
Are you a Motorola Mobility Lands Phone Expert? Answer questions, earn points and help others
