Follow this test and fix it. God bless you
As with many small appliances, regular maintenance makes a dramatic difference in how trouble free your electric iron will be. Even so, things can happen.
If the iron doesn't heat, make sure power is on to the outlet, check the power cord and check the thermostat and replace if necessary.
If the iron heats but steams improperly, inspect the soleplate and clean the vents and flush sediment out of the steam chamber
If the iron produces too much or too little heat, test the power cord Also test and, if needed, adjust calibration of the thermostat .
If the iron does not spray properly, inspect and clean the nozzle
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water.
