Question about Canon Rebel XT / EOS 350D Digital Camera
Will not auto focus with a smaller lens.
My cannon rebel works fine with the 75-300mm lens but the 28 to 90 mm lens will not auto focus.
  • evardakas May 10, 2009
    Hey thanks. I tried to isolate the problem by borrowing my friends same lens. Even with his lens installed I had the same problem. Its just strange how it works normally with the bigger lens. Thanks again. I will get it repaired.
This happened to my camera. wont autofocus but works with manual.
I cleaned the contact point of my lens and the camera.
simple as that it worked...
I actually cleaned it with "monitor wipes"
Posted on May 20, 2009
I had the same issue with my Nikon d60...my 18-55mm did auto focus but my 55-200mm only manual focused, i thought it might have been my camera as i heard that not all lenses are compatible with my d60 but it turned out to be the focussing motor or something that was damaged, it was making a very funny noise when it tried to auto focus with it,like a screeching sound..if this is the case you should get it repaired and looked at, also check on the lens if it says it is a AF lens,if so make sure th switch on the side of the lens is switched on AF not MF. hope it helps
cheers
Posted on May 09, 2009
SOURCE:
Cannon EOS Rebel XS won't focus
Switch the lens to "M" and focus manually, then take the photo.
iphoto27atyahoodotcom
Jan 10, 2014 | Canon Rebel XS / Eos 1000D Digital Camera...
Canon rebel xti focus issues
this does not seem to be like a problem in settings
please use a different lens and try the same
Aug 15, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
I have the Canon EOS - older model - and when using with my Canon Zoom Lens 70-300 mm it does not work on auto focus but will with manual focus.
Clean the contacts on the camera body and lens where they meet with a cotton swab lightly dampened with rubbing alcohol.
Sep 20, 2010 | Canon Rebel XT / EOS 350D Digital Camera
My canon rebel XSi will not auto focus
Actually what I found to solve the problem was to first set the lens in "MF" and practice taking a picture manually to see if that would work. When I did this, I discovered that the fine tuning portion of the lens was somehow stuck mechanically. I heard a loud click as I turned it. That was all it took to fix the focusing mechanism on the lens. Then I set to "AF" and Voila, the camera worked just fine.
Apr 04, 2010 | Canon EOS Rebel XSi Digital Camera
Canon 15-55 zoom: won't auto focus. My 70-300 on
focus ring on cannon ef70-300 zoom is stiff, jerky. how can i free it up.
Mar 14, 2010 | Canon EOS Rebel XSi Digital Camera
My cannon eos rebel x 35mm wont take pictures on auto focus acts like the timing is off. Works fine on manual focus. Have already tried different lenses, batteries, and cleaning.
Your AF module needs to be replaced. Or maybe the mirror part that bounces light to the AF module.
Another possible issue is light. The AF sensors need a certain amount to light to be able to see if its in focus. Some lenses don't allow that much light to pass, so the sensors can't focus the lens. Try a lens that passes more light, like the 50mm f/1.8 or point your lens at a very bright scene.
If increasing the light level doesn't solve it, it needs repair. You might check Ebay for a "parts" Rebel to have spare parts for your good one.
Jan 25, 2010 | Canon EOS Rebel X 35mm SLR Camera
Canon, wont focus, dark viewfinder
try cleaning the contacts on the bottom of the lens, where it mounts to the camera body. This is a simple step to take and one that I try to remember to do frequently when I am switching back and forth between lenses frequently. get a magnifing glass and look closely at the contacts on both the lens and body. I have 5 canon bodies and the 75-300 IS lens is one of my favorites. It is ALWAYS mounted on either an XTI or XSI and within arms reach at all times. I have a hook and hang it from the headrest of the passenger seat when driving so that it is always ready at a moments notice. I have never had a problem with that lens.
Jan 24, 2010 | Canon Rebel XT / EOS 350D Digital Camera
Sigma 70-300 mm lens wont focus
I was focusing to close to the subject & too much glare from a church window.
Sep 26, 2008 | Sigma AF 70-300mm f/4.0-5.6 DL Macro Super...
Iso to auto
On the back of the camera to the Right of the LCD there is a up-down-left-right-center switch. push the up one. (Labeled ISO) then use the same selector switch to select the ISO you want and then press the shutter half way down. If you are shooting in a low light situation, the auto focus sometimes will not work. Change the switch on the lens from AF to MF and focus manually.
Sep 26, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Tamron lens for Xti?
if it is an auto focus lens that works on one eos camera, it should work on almost all of them. the only known exception is that some high end extenders will not fit the eos1dmarkII as it protrudes into the opening too far.
but a good rule is that if it fits without any obstruction issues, it should work. try cleaning contacts on the lens and camera body. if that doesn't fix it, talk to Tamron. you can use it manually, but will not be as easy and you would get less predictable results.
my suggestion is to always go with lens from camera maker.
sounds like there is an issue with the tamron lens. not the camera.
good luck
mark
Dec 16, 2007 | Canon EOS 400D / Rebel XTi Digital Camera...
Canon Rebel XT / EOS 350D Digital Camera Logo
196 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Poul Brinchs Larsen
Are you a Canon Camera Expert? Answer questions, earn points and help others
