Yamaha RX-V1500 Receiver Logo
A
Anonymous Posted on Nov 29, 2013
Yamaha 1500 setup screen - Yamaha RX-V1500 Receiver
Yamaha 9000pro, Ps is ok but unit will not boot
You may need to perform a factory reset operation. Turn power off, hold down the DEMO button and turn the keyboard back on. The
screen should display 'Setup is initialising'. This will disappear after a few seconds and the screen will display its default. If that does not work you may need to re-install program disks, I think you should have 6 of them
1helpful
Message volume fixed
Zone 2 Setup on the RX-V773 using the ZONE2/PRESENCE Extra Speakers The RX-V773 extra speaker terminals can power one set of speakers for Zone 2 or Presence speakers. If the extra speaker terminals are utilized then the RX-V773 cannot be set for Bi Amp (Surround Back/BI-AMP terminals). Setting the Extra Speaker Terminals Note: The RX-V773 remote control will be used to access the On Screen Menu of receiver. 1. Press the On Screen button on the remote control to enter the On Screen Menu. 2. The On Screen display should be displayed on the TV/Monitor. 3. Press the Arrow Down button on the remote until Setup comes up in the screen. 4. Press the Enter Button on the remote control. 5. The Setup Menu will come up across the TV/Monitor screen. 6. Use the Arrow Left & Right buttons on the remote to navigate to Speaker. 7. Press the Arrow Down button on the remote to select Manual Setup. 8. Press the Enter Button on the remote control to enter Speaker Manual Setup menu. 9. Speaker Manual Setup menu with Power Amp Assign highlighted will come up. 10. Press the Enter Button on the remote control to enter Power Amp Assign menu. 11. Speaker Manual Setup, Power Amp Assign menu will come up with Basic highlighted. 12. Press the Arrow Down button on the remote to select 7ch+1ZONE. 13. Press the Enter button on the remote to select 7ch+1ZONE. 14. Press the On Screen button to exit the on screen menu. To control Zone 2 using the RX-V773 remote, the switch at the upper left side (above the BD/DVD Scene button) of the remote must be set to Zone 2. To see the operations on the front of the Yamaha receiver you must press the Zone Control button on the front of the receiver. Note: Only analog signals can be sent to Zone 2. If you want to output the sound from Zone 2, connect an external component to USB Thumb drive, USB iPhone/iPod, Network, AV 5-6 or Audio 1-2 by analog connection. For AM/FM radio the antennas must be attached.
Coaxial input is not functioning in Yamaha RXV 530
Do you have the receivers "Audio Input" set to "Auto?"
There is a small button on the front of the receiver to set audio for either: "Analog, Digital, or Auto" and you can double check it in the "On Screen Menu", "Manual Setup" "Audio" Hope this helps, if you still have an issue, check the "Source"(DVD,Cable Box, etc) setup mode as well.
Cant get anything when i use the two hdmi inputs in and one hdmi out to a monitor
First thing to check, If you turn your monitor on to the correct input you should be able to see an immage from your receiver. It may be a setup screen, blue screen or flash as you change inputs on the receiver. If you do not see anything from the receiver check the HDMI cable from the monitor out of the receiver to the input on your monitor. Next is the setup of the DVD player and the Yamaha receiver. Check that the receiver HDMI ports are turned on and assigned to the correct port. Check that the disc player is setup to out put HDMI and that formats like DTS are turned on if your receiver supports this. This will give you the best picture and sound out of the equipment you have. To get in to the set up of your DVD player and receiver and use the on screen display you may need to connect them to the monitor with a composite video cable first. Make sure the monitor is on the correct input. Once you have finished the setup you should be able to switch the monitor back to the HDMI input.
Have no sound when I connect the rear speakers
Open the "Menu" on screen, go to "manual setup" then "speaker setup" check your settings on "surround rear" and "surround back" If your not using zone 2 and zone 3, in the menu for zone 2 amp, select "Ext" and "Ext" for zone 3. If you still have an issue, post a comment and I can help you some more. I am a Yamaha Dealer. Hope this helps
No auto setup display on TV
For the setup functions you have to use either the monitor out (a yellow jack on the top-right corner of the back) or you have to use component video out. HDMI will NOT work for setting up the system. This is one complaint to Yamaha from all of us.
5helpful
3answers
Problem is starting Auto Setup on my Yamaha rx-v463 receiver
You need to press the AMP button before you press the ENTER button. Always press AMP first when selecting menu, enter, any surround mode, or one of the amp functions in ORANGE above the green numeric buttons.
Got this from Yamaha.
BG
2answers
Wiring
In order to see the OSD (On Screen Display) setup menus provided by the YSP1000, it has to be connected to a display device!
This is very clear in the manual which I gather you haven't read.
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Paul Bade
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
