Need remote control code
SOURCE: cant control tv with direct tv remote
I don't know what size TV you have but just installed Direct TV for parents and none of the codes worked after a LONG time my husband tried the Sears codes and got the last one he tried to work. He used 10056. It is a 47 inch LCD Proscan TV. If that doesn't work, you might want to try all of the Sears codes to see if one will work for you. Good Luck
SOURCE: proscan universal remote
Found these codes on the website for PROSCAN. www.oncorpus.com, for you model television.I hope this help you with your problem. UNIVERSAL REMOTE CONTROL CODE LIST
For Universal Remote Control brands listed below, please use accompanying Proscan codes
and refer to your Universal Remote Control User Manual for basic instruction for changing TV code to
operate Proscan model.
Proscan codes for Sony TV=8003,8012
Proscan codes for Philips TV=1005,1006,1007,1035,1064,1216
Proscan codes for other universal remotes=272,132,134,116,040,016,024,056,019,262
SOURCE: need a remote control code
hi,i had the same problem and found out that the samsung remote codes worked,try that.
