Polar S150 Heart Rate Monitor Logo
A
Anonymous Posted on Nov 28, 2013
How do I reset the time on my polar electro ce0537
3 Related Answers
Anonymous
  • 347 Answers
  • Posted on Dec 07, 2010
SOURCE: have a Polar CE0537 S725
If you go to my Tips and Tricks page, there is a link to the manuals for all Polar watches, including the S725.
To reset anything you need to access SETTINGS. On the S-Series watches push either the top right or bottom right buttons until you see the screen that says settings. Then push the red button to choose. use the right buttons again to scroll to the area you want to set. Keep repeating for every function you want to change.
As an alternative, the S725 connects to software that would have come with your watch, if you are connected to the computer through this software you can reset settings from the software and import them to your watch. The specifics of this are in the user manual.
Anonymous
  • 347 Answers
  • Posted on Jan 06, 2011
SOURCE: Polar electro oy CE0537-T41 N2965 chest strap Does
No. all the solid rubber straps are sealed in batteries. Only the T-31 wealink has a replaceable battery. The T-31 will work with your S-150 watch. If you need a replacement because yours has stopped working then that is an option. It's about $10- more.
lkjhbewgt
Artur
  • Posted on Dec 06, 2014
You can find them on amazon, here: Finally charging for our multi device world. Have a nice day
1helpful
I need the manual of my polar electro ce0537
Hi! Welcome to FixYa,
Please refer to the link below for the manual of polar electro ce0537:
http://www.polar.fi/en/support/product_support?document=/gip/PKBStoGIP.nsf/LINK/xAF42D5B7E6C545CF422569F400405E36?OpenDocument
You have a great day and thanks for using FixYA!
3helpful
My wife asked me to set the time on her watch. She no longer has a manual. Can you help? It is a polar CE0537 Polar Electro and has two side buttons but no button in front. Thank you.
There is a link to download any Polar manual in PDF form in my tips and tricks page.
Are you sure there is no button in front? Polar watches are all activated for exercise recording by a front button. And if it is an A5 as the request and picture show there is definitely a front button.
On the back of the unit, near the upper portion of the backing will be the model number it will be a letter/ number code like A5, M32, etc... The CE0537 is a different coding than the model itself. You will need the model number for the correct manual.
2helpful
Polar ce0537 watch screen goes blank or changes time and settings. reset the watch ad it happens again within twelve hours or less.polar heart rate monitor.
Have you had the battery tested? Try that, and we will go from there.Let me know, I can help you it just takes curtain steps to make sure we don't go through a bunch of things we don't have to in correcting this problem.
15helpful
Setting Polar CE0537
You do not have the right model number. For some reason, Polar puts the CE0537 in big numbers on the back of the case. The real model number on my unit was in very light engraving right above the words "Polar Electro" on the back of the case. Looks like they have an engraving problem where both the model and serial number are very hard to read. If it helps, my model was S120 and I found the manual quickly on the polar site. The polar site also has the location of model numbers in their FAQ area.
Top Polar Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
john h
ADMIN Andrew
ADMIN Andrew
Are you a Polar Exercise and Fitnes Expert? Answer questions, earn points and help others
