It is a known issue
Try first a general reset:
- remove the batteries from the clock (thus turning it Off.)
- remove the batteries from the outside sensor (if you are not aware that it has batteries, then perhaps it is not working because the batteries are no good any more! check that also.)
- wait 10 minutes with no power to the device.
- put batteries back in, power On again.
- hit Reset.
- hit Receive button.
- change the channel for reception from the outside sensor.
- change the channel on the outside sensor to match that channel.
- then set the time once more, once the remote temperature is sensed once again.
If this does not get the outside temperature reading working again, you may have to replace that temperature sensor.
https://www.google.com/search?q=Model+spc373
