Question about Necchi 3102 Mechanical Sewing Machine
Necchi 3205fa manual bobbin - Necchi 3102 Mechanical Sewing Machine
  • Necchi Master
  • 7,365 Answers
Try this link for what you need
Posted on Dec 03, 2013
SOURCE:
SOURCE: Have a Necchi 3205FA and
There is a serger attachment available for that model. When you attach it to the machine you must start the fabric from the top of the foot. The foot won't cut the fabric if you feed it under the foot. You will want to use the Wide zigzag, overlock, or hemstitch stitches. Set stitch length knob on #4 for overlock stitch #1-0 for hemstitch or zigzag. Set the stitch width to the maximum. Make sure the hook arm is inserted over the needle screw so that when the needle goes us and down the attachment will work. Start on the edge of your fabric by making a small cut about 1-2 cm deep and about the same distance from the edge as the cutting blade. This will make it much easier to feed the fabric over and then under the foot. Remember to start the fabric on top of the foot and then feed it under the foot before it reaches where the needle would penetrate.
Posted on Dec 06, 2008
SOURCE: bobbin case on my 524fb necchi has come apart
Almost all Necchi use a class 15 bobbin & bobbin case, a new case should cost around 7 to 10 dollars!
Dwayne
Posted on Mar 14, 2009
miket756
  • 2702 Answers
SOURCE: NECCHI, model 4795. Thread bunches up at bobbin.
it sounds like the thred tenshion is to loos or the timing has sliped a little and its off a bit this can also happen with wear on the gears or just a loos fixing letting the timing slip back a bit,
Posted on Nov 20, 2009
SOURCE: the needle jams when i start sewing
Could be threaded wrong - check manual for proper threading
Needle could be bent - check and replace if needed
Needle plate could be damaged - see if any burrs are on it if so take to service dealer and have removed
Bobbin could be wound wrong - check manual
Bobbin could be bent - if so replace.
Posted on Jul 29, 2010
  • 20 Answers
SOURCE: How do you load the bobbin on a Necchi sewing
What model Necchi SM do you have. Linda at Relics
Posted on Jun 18, 2011
Top thread too tight?
make sure tat the thread is between the tension plates and not behind and jamming on the bolt
proper tension is a slight resistance when you pull the thread to thread the needle
Oct 20, 2016 | Necchi Sewing Machines
Im trying to see if I can fix the upper tension spring on my Necchi 3205fa machine. I think it was stretched out of correct shape.
If the spring doesn't revolve easily while it catches the thread it may be. To see what the shape should look like you can go to Ebay and type in "Necchi 3205fa sewing machine tension control". This should give you some very nice photos. You may even want to purchase one from Ebay and replace the one you are having problems with.
Oct 04, 2016 | Necchi Sewing Machines
Where cn i purchase a power cord and foot controller for a Necchi heavy duty model 3205 fa?
http://www.sewingpartsonline.com/foot-control-and-cord-universal-419451-003.aspx
Sep 29, 2015 | Necchi Sewing Machines
I have a Necchi 3205FA ROYAL series sewing machine. It will not sew at all the only time the needle moves is when I click the bobbin in and then it only moves for a second then stops completely.Should
Can you turn the handwheel manually? Does it move freely? If not, the machine needs to be oiled. Check the manual for the proper oiling locations. Basically, any metal to metal areas require oil. Just make sure the machine is unplugged and avoid oiling the motor.
Oct 13, 2014 | Sewing Machines
Trying to find a sidecutter attachment for Necchi 3205FA
call or email these sites
sewvacdoctor.com
a1sewingmachines.com
Jan 08, 2013 | Sewing Machines
Ned a diagram (or detailed instructions) on to thread a Necchi 3205FA & installing the bobbin. Thanks.
try www.sewusa.com there are threading diagrams for some Necchi models. even if yours isnt there the bobbin should be similar.
Sep 20, 2011 | Necchi 3101 Mechanical Sewing Machine
Hi - I'm in the market for a sewing machine. I'm trying to decide between a Singer 4832C or a Necchi 3205FA. Which would u recommend? Thx.
I used to sell necchi's, I have used necchi's for over 30 years for sewing & quiting. I own a necchi model 4595 mechanical sewing machine, & a omega by necchi, model 6150, electronic, my husband does his quiting on it.I have made clothes & quits on both machines
I have never sold or tried a necchi 3205fa or a singer 4832c
all I ever had were old singers, which I have gotten rid of all them
make sure it has a operation manual with it.
make sure you can take it back if something is wrong with it.
happy sewing
Jul 23, 2010 | Singer 7442 Mechanical Sewing Machine
The needle jams when i start sewing
Jul 09, 2010 | Necchi Sewing Machines
Necchi Heavy Duty Sewing machine model 3205FA, bend needle while hemming denim skirt, replaced the needle, but now the needle is not picking up the bobbin thread, any suggestions for me to try???
Generally when the needle does not pick up the bobbin thread, it means the needle is either too far in or just plain the wrong length. YOu might want to try lowering the needle just a hair and see if that helps.
Apr 20, 2009 | Sewing Machines
Necchi 3102 Mechanical Sewing Machine Logo
122 people viewed this question
Top Necchi Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
