I bought a Craftsman rear tine rototiller tines can be switched to forward or reverse. I bought it got it home drove it off the truck, got it into the back yard and tried to engage the tines, i have not been able to get the transmission to engage anything, forward, nuetral, reverse, or the tines in any direction. I can roll the tiller in forward or reverse for about 2' and the tires lock up in both directions. how do i get it to move and engage the tines again? Both were working when i bought it an hour before hand.
SOURCE: Tiller goes For./Rev. but wont drive forward with tines engaged
check the sher bolt on the tine to drive shaft. ill need model and ser number off the unit before i can go further with helping you thy changed them around a lot
SOURCE: Own a "Craftsman Rear Tine
Can you move the tines by hand???
They should turn by hand if you try to move them...if not then they are bound up by something...
either a bearing has gone bad, something has wrapped around them, or there is something stuck in there that will not let them turn...check for a rock stuck between one of the tines and the housing around them...
Get the tines moving freely and you will be okay again...
heatman101
